does the crank position sender
  • gwb72tii
    • Nov 2005
    • 3864
    control the fuel pump and ignition signals at the same time?
    possible for it to send an ignition signal but not operate the fuel pump?
    “There is nothing government can give you that it hasn’t taken from you in the first place”
    Sir Winston Churchill
  • hoveringuy
    • Dec 2005
    • 2744
    It only generates a signal that goes to the ECU.
    The ECU generates the ignition and fuel pump signals. The crank position sender has nothing (directly) to do with either one of those.
      • 34844
      except that the ECU will not turn on the fuel pump, coils, injectors, or basically anything without a crank signal.
