E30 newby, oil change hell
  • Alkasquawlik
    • 4557
    It was the PO who overtightened it, I've never been able to get it off since the car has been in my possession.
    SC*AR
    Originally posted by JamesE30
    And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
    • e30trooper
      • 11576
      As long as you have the right tool its very easy , even when its over tightened. You need the tool that looks like a metal strap. sometimes i get a few hard ones at work but i manage to get them. Like yesterday I think it was a tahoe ( very easy cars to change oil on ) i ended up crushing the filter it was on so tight. The new honda civic SI's are a bitch you need small hands for that. Anyways when you put the filter back no need to tighten as hard as you can , just one and a 1/4 turn, clean it start ur car and thats pretty much it. Next time a e30 comes in ill try to record a vid
      • e30trooper
        • 11576
        you still cant get it off? how long has it been on there?
        • kishg
          • Sep 2006
          • 2624
          no need to crawl under.. reachable from top. wait till the engine cools off.. no biggie..
          '12 F30 328i Sport Line
          '91 SpecE30 #523
          '00 Ford F-350 Dually Tow Vehicle
          BMWCCA #360858 NASA #
          128290
          • Alkasquawlik
            • 4557
            I know HOW to do it, it's just a matter of that I CANT do it. I can't pull the damn thing off and it's been on my car for over a year, which frustrates me because I know it's not good for the car at all.
            SC*AR
              • 34839
              hmm, oil filter wrench + impact gun?
              • SpecM
                • Oct 2005
                • 4531
                I'm with Nando on this on, oil changes on m20s are a breeze. And the filters easy to change, I don't see what the problem is...
                and so is the housing seal for that matter
                Nando: you wife must have a Honda!
                1989 cirrisblau-metallic 325i
                  • 34839
                  nissan... hecho en mexico! :p
                  • kamotors
                    • Nov 2007
                    • 7102
                    a filter wrench/socket thing makes oil changes super easy. With stock headers I usually just reach in between the manifold and unscrew it by hand pretty easily, but with after market headers you need to just pop the oil filter socket onto the end of a ratchet and your done in 5 minutes.
                    7speedshop.com
                    • Alkasquawlik
                      • 4557
                      Ya, I stripped one of those. It was brand new too...
                      SC*AR
                        • 34839
                        was yours metal or plastic? Mine is metal. try a metal one with an impact gun, with the car hot.
                        • Alkasquawlik
                          • 4557
                          Mine was plastic, it was the only one I could find.
                          I'll try that next time I change the oil, thanks.
                          SC*AR
                          • kishg
                            • Sep 2006
                            • 2624
                            did you try a strap wrench? or poking it through with a screwdriver and getting it off? don't keep driving with a clogged up filter.
                            '91 SpecE30 #523
                            128290
                            • Alkasquawlik
                              • 4557
                              I tried a strap wrench earlier and that didn't work. I didn't want to smash it through with a scrwedriver because I don't want to ruin the threads and/or not get it off and be stuck with an oil filter with a hole through it.
                              SC*AR
                              • Naplm00
                                • Nov 2008
                                • 1573
                                get one of these at harbor freight
                                or
                                ive taken filters off that have been put on my a gorailla with the top one...it will mangle it, but it will come off
                                OR
                                you could just remove the 17mm hollow bolt holding the whole filter housing on the block and then the filter
                                make sure to get new orings for the oilcooler lines, bitch spring clip as mentioned above, and the hollow bolt and block
                                88 325ic ~~~> Rusty and ugly
                                85 E ~~~> RIP
