2.7i driveability question
  • slo325i
    • 417
    Hey guys,
    I'm right in the smack-dab middle of this project right now. I got the eta head off and I'm just prepin the i head and the intake manifold with the i injectors. I was just thinking this though....
    I'm just putting on the i head w/o milling/shaving or anything like that. I understand that the compression will drop. My question is, how the motor will run/drive with low-compression? what should I look for? Is it going to taker longer to start? Loss of horsepower? any loss in driveability issues?
    Justin
    '89 325i - Totaled... good bye my love...
    '87 327i budget stroker - SOLD!!!
    '92 240sx - ca18det powered drift toy - SOLD!!!
    '89 325i - coupe - NEW daily
    '96 Audi A6 Quattro- Grocery getter/baby hauler
    '99 Busa - weekend wheelie monster
  • Devil Inc
    • Jan 2008
    • 802
    My 2.7i runs fantastic, occasionally during the winter it will require an extra crank or two. Mine really screams once I hit about 3700rpm. It's no slouch down low either.
    • kenika65
      • Aug 2007
      • 1336
      Once Again!
      1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
      1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
      • Poopie
        • 295
        that car is running MS though. I would like to hear opinions on people running stock tuning.
        • Edev
          • 3731
          What cam did you use? My 2.7i runs flawlessly. No extra cranks. Just some of that, wob wob wob wob ;) It has a lot of get up and go, like you said.
          M Coupe
          • jmc1590
            • Jul 2008
            • 112
            I'm currently running an e2i with the stock 173 ECU. Early eta pistons with an 885 head. Compression estimated at ~8.3:1. It actually starts better now than it did when in "e" form. Driveability has no real issues, perhaps a slight studder when coasting under light load. Under a heavy foot, no problems. It just loves to run. And the dyno shows an increase as well.
            • slo325i
              • 417
              Great to know... Thanks guys!! Just got the head put on. Will adjust the valves soon... Wish me luck!
              Justin
              • kenika65
                • Aug 2007
                • 1336
                Wow Didn't know their were so many 2.7i's out there!!!!!
                WOOOOOT
                • Luis325
                  • 3847
                  Im in the process of finishing mine also... Just forgot to get the 325i sparkplug wires.... so now its not going to be running this weekend......this sucks....
                  1986 "C2 2.7 Alpina" Sedan
                  1987 325ic Black Vert
                  • slo325i
                    • 417
                    Ignition parts will go in soon. Swap almost done. Just dunno where the two holes are for up top near the valve covers...
                    • slo325i
                      • 417
                      She runs!!!!! so smooth!!!! Thanks for all your help R3v!!!
                      • MysterE30
                        • Jul 2009
                        • 113
                        I have the 2.7i and it's pissed :( it bogs and doesn't give half the power it should under load. New fuel pump fuel filter and plugs. Anyone know what's going wrong? Please help me. :'(
                        86' ES back from the dead as an I
                        • Devil Inc
                          • Jan 2008
                          • 802
                          check your O2 sensor and TPS sensor.
                          • slo325i
                            • 417
                            Timing belt on well?? I must have rotated the motor at least 20 times to verify i had TDC. I was paranoid cuz i knew I wasn't to tear this motor down again just cuz i didn't set the timing right...
                            • MysterE30
                              • Jul 2009
                              • 113
                              Hmmm. The O2 sensor is new but how would I go about checking the TPS and timing belt? (I'm also retarded. My bro is usually the one helping but he's no availibility. Just want to make sure I don't further blow things)
