msd blaster coil
  • Luis325
    • 3847
    msd blaster coil
    Anyone have the part number for the correct msd blaster coil 2?
    Is it 8202 or 8203? Or any other that works?
    1986 "C2 2.7 Alpina" Sedan
    1987 325ic Black Vert
  • SpecM
    • Oct 2005
    • 4531
    I have an 8202 on my car now, it works fine
    the bracket has to be bent to fit it tho
    1989 cirrisblau-metallic 325i
      For a stock engine there's no advantage to be gained from an MSD coil.
        • 34847
        there would only be a gain if you were experiencing spark blow out and/or had an ECU capable of setting dwell manually.
        since you are unlikely to be turbo'd or have engine management the only reason to "upgrade" would be if your stock coil was dead and you happened to get a good deal.
        • Luis325
          • 3847
          Yep mines dead found a new one for $40.
          Ill be getting it. Its cheaper than an oem one...and should help when I install my msd ignition 6a
            • 34847
            There ya go! :)
            • der affe
              Technical
              • Dec 2005
              • 8452
              is there any real gains to be had with 6al box and a blaster coil on an NA motor using the motronic 1.3 or is it better off with the MS in addition?
              • SpecM
                • Oct 2005
                • 4531
                that's why I have one, my stock one corrodded itself to the dizzy wire, and I picked up the MSD for $32 (this was two years ago) vs. about $70 for an "oem" coil.
                • E30_fiend
                  • Apr 2006
                  • 7348
                  I have one with low miles for 25.
                  let me know if youre interested
                  Taylor
