Brake Lining Light
  • johnleynes12
    • Dec 2008
    • 124
    Brake Lining Light
    Hey guys!
    I was wondering if you guys could help. It's a simple question regarding the brake lining light on the check panel. When it's on what is most likely wrong with my car?
    Thanks for the help
    85' 325e
    • 34844
    brake pads worn out?
    either that, or the sensor has gone bad, or is shorting on something. that's most likely.
    In 7 years I have never had the light come on due to an actual worn pad. It's always a broken sensor or the wires rubbing on something, giving a false reading. I finally removed the brake sensors and the stupid bulb from my cluster. It's lighting my OBC now. :)
    • Philo
      Ich esse kleine Kinder
      • 3334
      Same here. I keep a good enough check on my car that I don't need a light to tell me my brakes are bad.
      -tim
      Originally posted by Jordan
      I like the stance
      • johnleynes12
        • Dec 2008
        • 124
        Thanks guys! Appreciate the help!
        85' 325e
