Rainy Day in GA
  • Fingprep
    • Nov 2008
    • 27
    Rainy Day in GA
    Today I was driving home from lunch with the wife, it was raining very hard but the roads were draining nicely. In hard rain with clear roads the car runs like usual smooth and problem free. I made it most of the way home only 4 miles left to go, when I hit a puddle, the car went nuts the engine loss almost all power and the exhaust made all kinds of weird popping sounds. When I got home I pulled into the garage and checked the intake to see if it was taking on water it was not so started to check the engine bay for loose or frayed wires the quick search yielded 0 results. Does any one have any ideas of what the problem/s could be? Maybe the oxygen sensor shorting out or something?
    You might have splashed water up onto the ignition wires. Old ignition parts can result in misfires when wet.
    • Fingprep
      • Nov 2008
      • 27
      I have new ignition wires ,rotor and distributor cap.
      • Dirty E thirty
        • 50
        check crank sensor wires if its an i car its low the ground just guessing tho
        86 325e now 327iturbo hx35 ms2
        DRIFT CAR
        warped my mamifold sell me your RSI MANIFOLD
        • structured
          • 954
          my car did this when I washed the engine and water was standing where the plugs meet the wires.
          • Stevie30
            • Apr 2007
            • 1534
            Check the fuel injector plug located on the side of the engine directly under the throttle body. It doesn't like to get wet.
            1991 325ic and 1991 318is
            • Yogawrench
              • Jul 2009
              • 115
              Check the catalytic converter too!!! Several years ago I ran thru a street section where the water was 4" deep. My converter was owrn out and had holes. After slowly traversing this deep water (to avoid getting the engine wet) the damn converter filled with water and sputtered badly before dying.
              When I got the car up on a rack, the converter was full of water. Went ahead and bought a new one after that.
              1993 Alpine White II 325i convertible (last year of E30 production)
              1988 Zinnoberot 325 Super ETA coupe
              • Fingprep
                • Nov 2008
                • 27
                I just found a cracked wire on my flywheel position sensor could this also cause the problems?
                  • 34847
                  yes
                  • Fingprep
                    • Nov 2008
                    • 27
                    All right that's a start.
