327i question
  • Dirty E thirty
    • 50
    327i question
    so i have all my parts for my swap but im using forged eta pistons for the 327i swap and i know im gonna have low compression. does anyone know if it will have more power na than the stock eta motor. Or should i mill the head or block to lower the compression to make more power.
    thank you
    86 325e now 327iturbo hx35 ms2
    DRIFT CAR
    warped my mamifold sell me your RSI MANIFOLD
    • 37833
    Last I knew that combo is said to be like 7.9:1. Not a good ratio by any means.
    Unless you're planning for boost, I'd go with different pistons.
    Grover Beach, California
    BimmerHeads.com
    • Dirty E thirty
      • 50
      but if i mill the head or block it would lower the compression? right . so what im really trying to find out if anyone has mill or deck a block or head on a 327i for high compression.
      DRIFT CAR
        • 34844
        if you mill the head and block you'll have to get a cam gear to correct the cam timing.
        • spirit_of_mind
          • 8
          you could use m43b16 or m43b18 euro pistons with any 135mm conneting rods
          it gives you 9.1-9.5 CR
          or you could go with thinner gasket - 0.4mm would be enough to get 9.1 CR but timing will be shifted fo 1/3 of tooth
            • 37833
            Damn, 9.5:1 would be sick!
            If it were me, I would not mill the head, mill the block, OR run a thinner gasket. Just my semi-professional opinion.
            BimmerHeads.com
            • slo325i
              • 417
              Or just leave everything alone and boost it!!!
              '89 325i - Totaled... good bye my love...
              '87 327i budget stroker - SOLD!!!
              '92 240sx - ca18det powered drift toy - SOLD!!!
              '89 325i - coupe - NEW daily
              '96 Audi A6 Quattro- Grocery getter/baby hauler
              '99 Busa - weekend wheelie monster
              • Wh33lhop
                • 11705
                He could always mill it enough to alter timing by 7.5 degrees...
                :p
                paint sucks
                • eta
                  • 63
                  Your CR using a 9:1 eta pistons and an 885 head accounting for the volume of a crushed head gasket gives you a CR of 8.35:1 so not as bad as you thought. On mye28 there are folks who have built this motor as yo desribe and get 130 whp and 148 ft.lb wtrq. Definately more than a stock eta. Near the bottom of this link.
