Revving issue, won't rev past 5100rmp. 325is.
  • Vovchandr
    • Jul 2009
    • 18
    Originally posted by Red88
    Eta has the coolant resevoir on the passenger side, with a coolant hose going from the resevoir directly to the block, I has the res. on the driver's side and has a hose going to the radiator. I's look different to the somewhat trained eye. I own two i's and one eta, and know for sure beyond reasonable doubt that you have an eta. You posted pics of three i motors in your last post. One major quick reference is to note the more robust looking, and somewhat smoother curve in the i intake manifold.
    Yeah I've learned these things after reading the post and doing a quick basic search. I've posted pictures of I's as a reference to see exactly what I'm "supposed" to have.
    What I'm trying to figure out now is exactly who made this Frankenstien and exactly what parts were put on it.
    Is it an IS chassis with an Eta motor, or is it an Eta chassis with IS parts. I'll be pissed off if it's the latter.
    • nickpdx
      • 679
      Could be a 325es? Came with a lot of the same sport options.
        Run the VIN through realoem.com. That will tell you if the car was built as an i/is or e/es
        • chadthestampede
          • Jul 2008
          • 3601
          That's an eta if I've ever seen one.
          Originally posted by LJ851
          Feedback
          • Vovchandr
            • Jul 2009
            • 18
            This is getting better.
            Ran the vin and I get a 325I instead of Is, but I didn't see an option for Is either.
            Last 7 vin is 2325160
            The door sticker says 325i but it's layed over an older sticker the sticker next to it says Is.
            I'll link the pics when I get home, can't link photobucket from iPhone.
            • quickervicar
              • 1197
              Does it really matter? Sounds like you have a 325 with an eta motor. That's the bottom line, isn't it?
              • Vovchandr
                • Jul 2009
                • 18
                I would rather have the piece of mind that I got the chassis that I had in mind when I paid for it, rather than feel jipped.
                Motors change with a hoist, chassis change with a for sale sign.
                • Vovchandr
                  • Jul 2009
                  • 18
                  Just got a word from my salesman friend who ran a BMW history check on it.
                  It is indeed an IS... Mostly
                  • reelizmpro
                    • 9555
                    It's a year model thing due to the water pump/cooling system. The 87 325i had the tank on the passenger side. That's definately an ETA engine. I'd bet it's a 87 325iS car (with 7K tach, 3.73LSD) and someone replaced the engine with an ETA engine including wiring? Who knows. A lot can happen to a car in 20 years.
                    88 M3 - LACHSSILBER
                    89 M3 - ALPINEWEISS II
                    • Vovchandr
                      • Jul 2009
                      • 18
                      Moar pics.
                      IS Trim
                      IS tach
                      IS/I stamps, note the overlayed stamp over an old one.
                      ECU
                      Unconnected plugs, either left over after the swap or half assed previous owner(s)
                      • reelizmpro
                        • 9555
                        Looks like someone replaced the engine, wiring and DME with one from an ETA at some point. Compare the VIN's on the stickers with the VIN on the front cowl and see if it matches. Sorry bro.
                        88 M3 - LACHSSILBER
                        • Vovchandr
                          • Jul 2009
                          • 18
                          Which cowl? So far the dash/engine compartment/door VINS all match.
                          No need to be sorry, neither of the motors is all that great, this one is just lesser great.
                          If anything that just means that it's likely to have less than than 230K miles as the body has, making it more likely to be reliable as it sits now until I find a suitable replacement.
                          Where should I look for the engine stamp on the block?
                          • Vovchandr
                            • Jul 2009
                            • 18
                            Where is the engine stamp for the bottom end?
