Ok, my car decided to be a bitch with me lol, I fix one thing and another one brakes. I am having problems with the fuel pump, it has no power at all, I change the relay and still nothing, I tried another ECU I have and still nothing I checked all the sensors and nothing seems to be wrong and most of them were replaced. I need help plz, the car is 1988 325i convertible it's manual, if you need more info ask me, thanks[/FONT]
Electrical problems
Tags: None
The fuel pump relay is controlled by the DME and only engaged when the DME see's timing data from a rotating engine. If you don't have spark and fuel pump operation when cranking over the engine the possibilities are;
No power to the DME
Bad main relay
Lack of timing reference data to the DME
Bad DME
If the fuel pump relay closes and the fuel relay is good but you don't see power to the pump there is a fault in the wiring.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
Have you jumped the relay to see if your fuel pump is working? Or are you just turning the key?Yours truly,
Rich
Originally posted by Rigmasteryou kids get off my lawn.....Comment
Get a Bentley it has an ECU diagram and a list of diagnostic tests to run using that connector. Use the ECU connector to do multiple jumps. That will tell you a whole lot about the wiring and the operation of the pump. It's pretty easy to do, you just need a jumper wire with a fuse and a multimeter.1987 E30 325is
1999 E46 323i
RIP 1994 E32 740iL
oo=[][]=ooComment
