M20 Bore Size
  • M5W
    • Aug 2009
    • 134
    M20 Bore Size
    Has anyone hear bored out their block to 86mm and if so any results or issues from it ?
    • 34844
    yes, lots. and no issues.
    • M5W
      • Aug 2009
      • 134
      k cause after reading about dan's issues on a stock bore im worried ill be testing the wall thickness of my bores since I wanna push around 400-450 out of it.
        • 34844
        Dan Pinder? what problem did he had? he seems to like to learn things the hard way. only problem I know is his motor blew due to an unexpected lean condition at 20psi.
        • M5W
          • Aug 2009
          • 134
          Ya but that lean condition cracked his block I believe and caused it to hydrolock. He had a stock block thickness, I will have 2mm less.
          I know it was caused by a lean condition, Im going to have my megasquirt checked out before I start tuning on this turbo setup.
            • 34844
            that was a pretty catastrophic failure, the thickness of the block wasn't going to make any difference. He was also running a really high pressure ratio and pushing his turbo to the limits (that means high exhaust pressure too).
