head bolts?
  • e30loverSC
    • 575
    head bolts?
    IM looking for some new torx head bolts for my 87 325is? wheres a good place to get them and how do you torque them?
  • DoriftuEvo
    • 236
    Bought mine here
    McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
    Torqued with this
    • dashboardmonkey
      FUCK YOUR WAFFLES
      • Jun 2008
      • 6158
      metric blues are a good replacement for stock, iirc they can be retorqued too
      -Andy
      • e30loverSC
        • 575
        ok so i bought teh torque bolts from pelican parts they Are torx. im not sure what size head.. and how do i tighten each one ? like 30nm... then what?
        • yert315
          • 2734
          should have upgraded to the hex style bolts that the later motors came with.
          Regardless, here are the specs per the Bentley:
          Stage 1: 30Nm (22 ft. lbs.)
          Stage 2: 90°
          Stage 3: 90°
          On engines with Torx head bolts, the torque angles can be done with engine cold. There is no specified waiting time or engine temperature.
          Torque Sequence: "O" are head bolts.
          Hope this diagram makes sense
          front of engine --->
          12---10---4-----2----6----8----14
          O___O___O___O___O___O___O
          13---7-----5----1----3-----9----11
            • 34844
            yuck
            they aren't really headbolts, they're just bolts that happen to be the same thread pitch and length as E30 bolts. who knows what the quality is. Stock bolts are cheap and work great on a stock motor.
            • e30loverSC
              • 575
              where can i get the stcok head bolts from.. and what is the torque for them. I saw it in the bentley but i dont understand it really?
              • yert315
                • 2734
                You said you already bought bolts from Pelican. Use them, they will be fine. I believe they are a t12 or t14 head (inverted torx socket).
                I just gave everything to you straight from the bentley. 90° is the angle you have to turn them. Take a breaker bar and a right angle (with degree marks) and go at it. This is the cheap ass way to do it, but it works. The other option is to buy a torque angle wrench.
                • whodwho
                  • Jun 2008
                  • 1547
                  The Torx ones are replacements for the early hex style that the heads were known to break off.
                  My M20 Frankenbuild(s)
                  4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                  • 87bimmerguy
                    • Jan 2008
                    • 123
                    Stage 2: 90°
                    Stage 3: 90°
                    Do this^^^
                    This is backwards. The torx heads replace the old hex heads.
                    Your pelican bolts will be fine. I have inverted torx sockets you can borrow if you want to come to Taylors, or you can buy them at Advance Auto Parts like I did.
                    • StereoInstaller1
                      GAS
                      • 22679
                      Torque angle wrenches really aren't that expensive
                      Closing SOON!
                      Thanks for 10 years of fun!
                        • 34844
                        I made a torque angle gauge with an old CD and a protractor :p
                        • 3bvert
                          • 1032
                          use a prpotracvtor, like the cd idea.sure go tplenty of dead ones around
                          • Mike
                            • 932
                            IMO, for achieving the 90/90 angle torque, just take a chisle on the head of the bolt and make a perfect verticle mark on each headbolt, after initially torqued with torque wrench. That will eliminate that angle torque guage stuff.
                            Supatek -noun - your basic know it all
                            • Conrad311
                              • Oct 2009
                              • 370
                              I just used a craftsman torque wrench to 22lb/ft and then used a 18" breaker bar with the E-14 torx socket and it worked like a charm. Forget about using a standard length rachet for the second round of 90 degrees, get a long breaker bar and it will be like nothing
                              "In God we trust. All others must bring data." -W. E. Deming
                              /// 1987 325is /// Project Thread
                              Past: 87 is, 88ix, 88 i, 87 ic, 89 ix, 17 others.
