Question about 2.8L Stroker(ECU Programming)
  • E30driver37
    • Jan 2010
    • 36
    Im going to stroker my M20 and im trying to plan it out. I so I have a question about the ECU and Programming I was talking to a engine rebuilding company and they said if I mess with the crank and cam to stroker it and bore it out I will have to reprogram the ecu and that could cost 1500 is that true?
    • 34847
    it will run fine on the stock computer with a chip - but they are right, in a way. you need a tune to get the full potential out of your motor. That could mean a custom chip, a piggyback, or a full standalone computer.
    I wouldn't spend $1500 on the stock motronic computer though, you could do a much better stand alone computer for about $1000 and get rid of the AFM among other possibilities (sequential injection, no more cap/rotor, etc).
    I would reccomend, however, that you break the engine in on the stock computer, with the stock chip. it will be a "safe" tune so you can focus on engine break in, rather than trying to do that and learning how to build/wire/tune a whole engine management system at the same time.
    • E30driver37
      • Jan 2010
      • 36
      Thank you for your input. I think I need to do more research. How reliable is this 2.8L set up.
      The main reason for the stroker set-up is that I hope to turbo this car next winter.
      • Danny
        • 14216
        Well that's perfect for you if you buy the set up i'm selling.
        • E30driver37
          • Jan 2010
          • 36
          I need to talk to my Re-builder then I will get back to you.
          • Danny
            • 14216
            Right on.
              • 34847
              as reliable as a stock motor, unless somebody screws up building it.
