M20 flywheel swap
  • gasgasrider
    • Nov 2009
    • 151
    M20 flywheel swap
    In the process of changing from a dual mass to single mass flywheel, I have come upon this question that hopefully some of you more experienced ones can answer for me... The single mass is about half an inch thinner than the dual, so the stacked height of the flywheel, disc, pressure plate and release bearing doesn't appear to be high enough for the clutch slave cylinder to move the release bearing arm far enough to properly disengage the clutch. If you've done this and understand my poorly worded question please share your info.
    • 34847
    you need a pressure plate/throw out bearing for a single mass flywheel.
    • JMPAuto
      • Jul 2009
      • 356
      Dual mass and single mass flywheel have different clutch kit.
      JMP Autowerkz
      7349 Canby Ave.
      Reseda, CA 91335
      818.457.4967
      www.jmpauto.com
      • Luis325
        • 3847
        Im about to do the same thing.
        So what we need is a single mass flywheel with a single mass 325i clutch kit...??
        1986 "C2 2.7 Alpina" Sedan
        1987 325ic Black Vert
