cam seal
  • NC325iC
    • Mar 2004
    • 6565
    cam seal
    is there some kind of secret to getting the cam seal out of its little metal ring?
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    pry it out with a screwdriver
    -Andy
    • bataangpinoy
      • Jul 2008
      • 1636
      yes. i bolted the flange to a spare head i had(no cam) then i took a slip wrench and pulled that thing right out without messing up the bore.
      My feedback:
      http://www.r3vlimited.com/board/showthread.php?t=186328
      http://e30tech.com/forum/showthread.php?t=74911
      Instagram:
      @gears_n_glory
      @functionmotorsports
        • 34839
        did you remove the seal housing or are you trying to do it on the head. you should be able to get it out easily after unbolting it.
        • cyberkaa
          • 1698
          I supported the flange on two blocks and gently tapped the seal out with a hammer and screwdriver.
          -Kalim
          British Racing Green, IE Springs/Bilsteins, IE exhaust, IE SSK,
          Momo shift knob, Miller MAF conversion, K&N intake,
          Blackworks Aluminum Radiator, 5MT swapped,
          Ellipsoids w/DDM HIDs, OEM Recaro Sports, Momo Mod07 Wheel,
          Drilled+Slotted Rotors, Alpine HU/Amp/speakers, 12" enclosed sub
          • NC325iC
            • Mar 2004
            • 6565
            come on nando give me some credit, 4-5 years of engineering school teached me up goodly.
            i have the housing off, the seal is in there though, I think i might have to heat it up some today when i get home, cause its not movin at all.
            • SkinnyVT
              • Nov 2008
              • 391
              This should be stupidly obvious but the seal can only go out one direction.
              '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
              • NC325iC
                • Mar 2004
                • 6565
                and you quoted the post saying im an engineer to point out the obvious to me...
                • SkinnyVT
                  • Nov 2008
                  • 391
                  yes...90% of the engineers I work with have zero technical ability, not saying that you don't but sometimes there is a stupidly simple reason things don't work.
                  • e30rapidic
                    • 2167
                    If you screw it up, I have an extra housing in a box. Located in north raleigh. I was worried about breaking mine as well when I swapped it out a couple of weeks ago. Ended up using a large socket and braced the housing over 2 2x4's
                    you can help me with my engineering (civil) homework in exchange..lol
                    '87 325ic, powered by S50.
                    • NC325iC
                      • Mar 2004
                      • 6565
                      i know what you mean, i have classes with those nerds
                      • NC325iC
                        • Mar 2004
                        • 6565
                        and youre right around the corner from me, i live in durant trails.
                        but im a mechanical... my grandfathers a civil, you could ask him, but he probly wouldnt be much help.
                        • e30rapidic
                          • 2167
                          my mom lives in Alyson Pond! that's where my cabrio is living until we finish our new house. N2MYE30 lives right down the street too.
                          do you live near the tennis courts??
                          • IronmanE30
                            • Sep 2009
                            • 2121
                            I use an Arbor press and two large sockets. Easy out easy in. I have seen it done with a vise but that's harder to get things lined up cus you can't stack them as easily. I have also done it the way described above but using 2 large sockets and a soft headed hammer.
                            Cheers,
                            Jim
                            • NC325iC
                              • Mar 2004
                              • 6565
                              nah, its actually in anson grove, right up against durant road, just off of cub road
