Super Eta AFM vs 2.5 AFM??
    • 37832
    Is there any difference between an air flow meter for a Super Eta and a standard M20B25 AFM?
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    You could check the part numbers on realoem.com.
    • eta
      • 63
      Yes there is a part number difference. The difference however is the electronics to suit the motronic 1.0 found on the eta's. The 325i and eta AFM are the same other wise.
        • 34839
        no they aren't. the eta AFM is much smaller. also, the seta uses motronic 1.1, not motronic 1.0. the motronic 1.0 AFMs also output a different shaped curve. than 1.1/1.3 AFMs
        • Flash
          • 688
          Just the way its tuned
          • E30Eric
            • Sep 2007
            • 156
            The SuperETA AFM is the same in shape and size as a normal "i" AFM. It's Motronic 1.1 since it's an 88. I sold mine to a guy with a 325i and he put it on right in front of me and we took the car for a test drive and it seemed normal.
            1988SuperETA|Full I component swap|19lb injectors|Schrick 272|MSIIExtraBeta20071020|GM DIS Wasted Spark|LC-1
              • 34839
              I said eta not seta ;)
              I also said the seta was motronic 1.1...
              • Danny
                • 14216
                I think he was agreeing with you
                  • 34839
                  it's hard to tell lol
                    • 37832
                    So if I have an i head and 173 on my Super Eta motor should I get an i AFM or are they the same?
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • SpecM
                      • Oct 2005
                      • 4531
                      use the "i" afm, the resistance curves are different (they are the same mechanicly, tho)
                      1989 cirrisblau-metallic 325i
                        • 37832
                        Thanks fellas.
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • eta
                          • 63
                          Please take a look at this link. It is for a July 1988 325e. It shows compatability for the AFM with the E34 520i, 320i and late 528e's.
                          Having cmpared a 325i AFM and an Eta one the intake boot fits over both so the are phyically the same size. The flap size look similar but without measuring air flow on a bench I cannot comment.
                          Fundentally I was saying there is a difference.
