Which is faster?
  • 2.5-12
    • Jan 2010
    • 1814
    #31
    can I chip a 173 M20B25 ecu?
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
      • 34844
      #32
      uhm yes? that's probably for another thread, or a google search engine. ;)
      • 2.5-12
        • Jan 2010
        • 1814
        #33
        yeah, realized this was hardly the place to ask that just after posting :oops:
        • StereoInstaller1
          GAS
          • 22679
          #34
          Originally posted by rcfanatic
          Awesome - thanks for the dyno sheets and explanation. I think that pretty much puts it to rest
          I thought it was put to rest last year!
          Closing SOON!
          Thanks for 10 years of fun!
            • 34844
            #35
            it's always going to pop up because it seems like the obvious solution. Cheap easy power right? Except that magic pixie dust that gives you lots of horsepower for no money doesn't really exist..
            • 5KWattson
              • Apr 2009
              • 809
              #36
              try red bull in the gas tank
              "God created turbo lag to give V8's a chance" Taylor D.
              • JasonC
                Site Manager
                • 14451
                #37
                Putting an i head on an eta does not make it a stroker.
                1992 BMW 325iC
                1978 Chevrolet Monte Carlo
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  #38
                  +1 idk why people call it a stroker. Isn't a stroker when you bump up the displacement to get power? with an i head on an eta the displacement still stays at the original 2.7. Now with a different crank, etc that is a different story.
                  Originally posted by Wh33lhop
                  VANOS: sometimes you just need to go full retard.
                  • digger
                    • Nov 2005
                    • 6183
                    #39
                    ETA with I head, exhuast and induction
                      • 34844
                      #40
                      that's probably one of the better ones. Added to my collection :)
                      • BMWLOVE100
                        • 11
                        #41
                        i think the 325i
                        BMW E21 CARS BMW E30 CARS MK2 GOLF GTI
                        • rcfanatic
                          • 490
                          #42
                          http://www.r3vlimited.com/board/show...5&postcount=12
                          When Mitch says run all the I parts, you think he means pistons, rods, crank, intake, exhaust, flywheel? But if that was the case, he would have a full I engine right.. the block is the same correct?
                          From nando's dynos, the power Mitch makes looks too high for just 885 head, b25 intake and exhaust. Then again maybe milling it has that big of an effect.
                            • 34844
                            #43
                            it's probably the milling.. we're talking a .2l displacement increase, but almost a full point drop in compression. The loss in compression more than makes up for any slight displacement increase.
                            • rcfanatic
                              • 490
                              #44
                              Does anyone know what the piston-valve clearance is when using the seta pistons? I wonder what kind of power you could make with seta pistons + milling
                                • 34844
                                #45
                                it's probably similar to the i motor
                                I think it really only becomes an issue with aftermarket cams - where even a stock, unshaved head/block can lead to piston/valve contact at TDC.
                                plus it's not that difficult to cut the valve pockets a little deeper.
