wtf M20
  • e30euro
    • Jan 2010
    • 2219
    wtf M20
    hey yall i got a problem ok here we go. i got a running problem but its not bad its miss firing like hell than shes fine and runs like a tank i put new plugs cap rotor coil and still but its not as bad i dont have an o2 yet got to get that done but still she should run fine just a pre set air/fuel i know its not the cps but i think its the mafm any one with hints thanks
  • 2.5-12
    • Jan 2010
    • 1814
    check for vacuum leaks, happens all the time.
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
    • Adrian_Visser
      • Jun 2006
      • 2823
      So you have no O2 sensor and you wonder why it runs bad? If you have a late model car i.e. a 173 dme it adapts the closed loop fuel map based on the o2 sensor readings when it is in open loop mode so no o2 sensor means it will run like shit. Change that and get rid of vac leaks.
      '89 Alpine S52 with goodies
      • hotballs
        • 1155
        you don't have to run on o2 sensor.
        • digger
          • Nov 2005
          • 6162
          i ran mine a while ago without O2 and it runs fine
          • uberCerealkiller
            • 221
            i think he meant that he hasnt replaced his o2 sensor yet.
            Originally posted by Beastolizer
            what is the difference between the 12 LED and 6 LED and 24 LED?
            Originally posted by norcalE30
            you may want to sit down, this is complex...
            one has 6 LEDs, one has 12 LEDs, and one has 24 LEDs
            • e30euro
              • Jan 2010
              • 2219
              ok well i put long tube headers with custom flanged exhaust full dual 2 inch into a single twin tip muffler and i havent got the bung plug on yet about to in a few days but i think it the mafm i have the bav auto intake kit with the kn filter does that help more?
              • jeffw
                • 1087
                check for vaccum leaks then test the afm with a ohm meter. it should start out about 3.25 and as you SLOWLY open the barn door should raise over 4.5
                • e30euro
                  • Jan 2010
                  • 2219
                  ok i will do that tomorrow i will head to my buddy's shop "BMW Dealership" lol he will check it for me
