m20b27 Clerification Please. Sensor In Spark Plug?!?
  • Fcknslo
    • Nov 2009
    • 171
    Yeah, I have to much dumped to go ahead and go get more. thanks man you have been a lot of help. so afm is something I should look into, what else causes these symptoms? everyon says cold start valve or vacuum leak but I don't have one.
    • kronus
      • Apr 2008
      • 13020
      AFM is the only thing I can think of, really. If the CSV is jammed open, it would just run like shit instead of starting and dying, and an m20 will start and run (roughly) with a vacuum leak.
      A humongous vacuum leak can cause a similar problem to the AFM not working, but you say you've looked for one already. Check the intake boot for cracks between the ridges, those are sometimes easy to miss.
      cars beep boop
      • Fcknslo
        • Nov 2009
        • 171
        yeah. the intake boot has a seroius crack and i tried covering it with duct tape lol.
        • kronus
          • Apr 2008
          • 13020
          Replace it.
          cars beep boop
          • Kershaw
            • 11822
            definitely replace the intake boot. vacuum leaks really mess with the engine.
            the afm (now that i know its called that and not maf, heh.) on my car is bad. if i want it to start in the morning i have to unplug the wire to it and then start the car with a little bit of revving. after i idle it a bit i can plug it in and it'll be so-so, but it'll run.
            so give it a shot, unplug the afm, and then try to start it.
            AWD > RWD
            • Fcknslo
              • Nov 2009
              • 171
              tried to do that and failed. any other ideas/ intake boot is pretty secure, what other factors cause a car not to start. i do have spark fuel and air.
