Broken Rocker Arm Question?
  • bimmer_E30
    • 5001
    Hey,
    So i got a broken Rocker arm on my M20 (Cylinder number 6)....it's all fixed and got the valve adjusted too.
    But since i only got the broken rocker arm replaced not all of them, could this problem happen again?
    what causes this problem to happen anyway? Weak Head?
    Originally posted by e30e
    While some folks claim that operation at the high end of the rpm band causes rocker arm failure, I've also seen them fail on automatic street cars that never see the upper end of the rpm band. Accordingly my theory is that the arms fail from repetitive shock loading that results from a lack of timely valve adjustments perhaps aggravated by worn valve guides.
    • StereoInstaller1
      GAS
      • 22679
      Caused entirely by lunar cycles, nothing short of witchcraft will fix them permanently
      Closing SOON!
      Thanks for 10 years of fun!
      • bimmer_E30
        • 5001
        oh i see.
        Well i told them to throw a new: timing belt, Tensioner, Spark plugs+wires also put my stock airbox back.
        I can see the Reliability walking it's way to me finally Lol.
        • blocke
          • 1305
          Originally posted by bimmer_E30
          oh i see.
          What about a water pump and seals while they are in there?
          Parts Wanted
          The Never-ending Resto Mod
          • bimmer_E30
            • 5001
            If water pump fails i don't care Lol. i could replace that my self.
            Seals, i don't see leaks anywhere! :)
            • StereoInstaller1
              GAS
              • 22679
              PM me when you need my witch's phone number
              Closing SOON!
                • 34847
                that, and fatigue of the metal, and soft valve springs leading to float.
                • Slangbox
                  • Jan 2009
                  • 599
                  Wait you can replace the waterpump yourself but not the timing belt? Please do explain
                  Body roll+perspective=the poor man's drop
                  • bimmer_E30
                    • 5001
                    No this shit again.
                    :weak:
                    • Slangbox
                      • Jan 2009
                      • 599
                      No this shit again.
                      :weak:
                      What?? What am I missing?
                        • 37834
                        You do know you have to pull the timing belt to change the water pump, correct?
                        Grover Beach, California
                        BimmerHeads.com
                          • 34847
                          no you don't ;)
                          • SpecM
                            • Oct 2005
                            • 4531
                            Originally posted by nando
                            no you don't ;)
                            not technicly, but it makes it easier
                            and you might as well ;)
                            1989 cirrisblau-metallic 325i
                            • StereoInstaller1
                              GAS
                              • 22679
                              Hmmm GRAF water pump was $60 or so. Timing belt kit was $35 or so, add a few bux for a couple of seals, get on with it.
                              Closing SOON!
