What DME Is This?
  • blitzed310
    • Sep 2007
    • 41
    What DME Is This?
    I'm not sure what DME this is. This is from my 323i with a M20B25 swap and I'm trying to sort this out.
    From what little I know on Motronic, this would lead me to believe this is a 380. Is that correct?
    I was told this was chipped with a cam, so after removing the DME to verify, I'm not sure if it's a reflashed chip or what. So what DME is this? I was looking to get the Miller Performance MAF/chip, 19# injectors, etc.
  • blitzed310
    • Sep 2007
    • 41
    Found this info for the DME:
    325i/is/iX
    E30
    M20/B25 (170hp)
    Bosch Motronic M1.3
    0 261 200 380
    Can this still be used with the Miller MAF?
    • blitzed310
      • Sep 2007
      • 41
      Probably should have searched a little more prior to this, but it seems like the 380 is an updated version of the 173 with more fault codes. Am I on the right path here?
      • stumble_t
        • Aug 2009
        • 759
        Link to list of ecu's
        Yea as far as I know the Later # ecu's (post 173) had better idle control. As far as fault codes, I thought all 1.3's were the same, seems plausible though. Someone once said to me the 525&6 had a top speed limiter but i've never confirmed this.
        [IMG]http://www.r3vlimited.com/board/
          • 34844
          it's post 153 that had better idle (more due to having one board, instead of dual boards and way more components to fail). 173-526 are all the same hardware wise, with very minor component revisions and small software updates.
          but in any case the 380 should work fine with a miller MAF
          • blitzed310
            • Sep 2007
            • 41
            Thanks for the info. Miller Performance confirmed: The 380 ECU is compatible. The 173, 380, 381 and 525 ECU's are all interchangeable so you would choose the 173 option.
            • Sagaris
              • Sep 2009
              • 2243
              ^525 should be 524 (for posterity) My 524 automatic trans. ecu works with a chip that was made for a 173 manual.
                • 34844
                there are 524, 525, and 526 ecus. It's not automatic specific - they came on california emissions cars.
                  • 37833
                  Let me know if you need a 173. :)
                  Grover Beach, California
                  BimmerHeads.com
                  • blitzed310
                    • Sep 2007
                    • 41
                    I need 19# injectors.
                    • Tismael711
                      • 791
                      Very nice E21....very nice!
                        • 37833
                        This thread is almost 2 years old and about a DME. There was no need for you to bump it.
                        BimmerHeads.com
