Broke a rocker arm, replace the springs?
  • plmichal
    • 718
    Originally posted by wakeboardr42393
    I just don't get why I seem to be the only one having this problem so consistantly (i've only had the car for about 7k km; less then 1 year). I have searched and have found zero cases where people have experienced 4 subsequent rocker arm breakages.
    I ran my m20 hard and snapped a rocker arm one time. Cylinder #4 intake. I replaced it and took it easy for a week. I slowly began to run the motor hard and within a month of replacing the first broken rocker arm, another one snapped. This time it was Cylinder #5 intake. I had done a valve adjustment prior to both arms snapping. I got tired and swapped in an M50 that month.
    Had I kept replacing individual arms, I believe that they would have kept snapping. That M20 was fantastic and I wish I would've refreshed/rebuilt the head. If I were you, buy a rebuilt head or have your current one rebuilt with new parts.
    1990 325is Brilliantrot/Natur
    • Earendil
      • 1662
      The reason is because standard procedure would be to replace all rockers at the same time. The are inexpensive compared to the labor, and no one want to end up breaking 4 rockers and paying the labor 4 times in a short period of time. Obviously, the equation change some when you are poor and do the work yourself. You have 12 rockers, they will all break given enough time, the question you face after losing 4 is, how long until the last 8 go?
      Losing 4 in that short a period of time isn't written about often, but broken rockers in these cars IS for whatever reason. By design or not, given other problems, the rockers will break, and age and stress only serve to break them sooner. If you can spring for it, replace as many rockers as you can.
      1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
      2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
      I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
      • digger
        • Nov 2005
        • 6194
        Originally posted by jlevie
        Intake valves are smaller than the exhaust valves.
        From what I've seen, my theory on broken rockers is that they fail due to a history of improper clearance (too loose). The repetitive impacts cause the rocker to eventually fail.
        intake valves are 42mm vs 36mm for the exhaust which is a fair % mass. the heavier the valve the more shock (inertia) load you get if the rockers are not adjusted correctly.
        • TobyB
          • 5287
          Jim got it backwards. I suspect a typo. Intakes are bigger and much heavier,
          and the springs are all the same.
          Intakes always break first. Only time I EVER broke an exhaust, the sucker had a void
          in it the size or Texas. Said BMW on it, too...
          If the head's apart, measure the valve springs. Replace the intakes if they're not
          at least stock rating. Since, at 180k, you'll want to at least do valve stem seals and
          you'll have the valves off anyway.
          If the lash pads and cam don't look so good, now's the time to just bite the bullet and
          do the head. It's not all that expensive, and it'll go another 150k- you can even stick
          it onto another bottom end in a while...
          jus' sayin'...
          t
          • wakeboardr42393
            • Apr 2013
            • 186
            So you're saying the aluminum just gets old and more prone to cracking over time?
            And yeah, I probably should have them all replaced. this one's already ordered and hopefully almost here. if another one breaks I will consider doing them all as well as looking at the springs. i suspect i may have a teeeennnnyyyyy head gasket leak as well, but i'm not sure. if i do i'll noitce at some point. the thing that's making me wary of doing a full rebuild is that if i will be rallying the car, idk how long the thing will last. haha. i'd ranter have money to race and then risk having to repair it then not have enough to race and have a newly working car :P
            some of you will like this lol: my gramps said they used to replace springs with the head ON. by connecting compressed air to the end of a compression tester, pressurizing the cylinder and keeping the valves closed.
            I haven't taken the head off to replace a rocker. it's not hard with head on.
            what would i do with the head rebuild anyways? I assume:
            • rockers
            • springs (after testing bad)
            • valve stem seals
            • valve grind
            • all related gaskets
            • timing belt
            what am i missing?
            is it reasonable/possible to get the top of the valves machined to get rid of the divot, so i don't have to do cam-side adjustment?
            '87 325is [because racecar]
            '81 Kawasaki KZ550 LTD {summer dd}
            '97 Subaru Legacy Outback Limited (winter dd)
            • digger
              • Nov 2005
              • 6194
              • rockers
              • valve stem seals
              • valve grind
              • timing belt
              what am i missing?
              aluminum is terrible in fatigue.
              add a new camshaft if all new rockers IMO
              • TobyB
                • 5287
                It is. Ironically, however, the new rockers seem to be more prone to breakage simply
                due to poor quality control. I had an especially hard time with the 2002-
                getting a decent set of OEM rockers became an expensive proposition.
                But then Ireland came out with the HD's for a very reasonable price...
                t
                • digger
                  • Nov 2005
                  • 6194
                  t
                  the last two sets ive used are the MM inspected and peened rockers and so far so good..... touch wood
                  • wakeboardr42393
                    • Apr 2013
                    • 186
                    why a new camshaft if no noticeable wear? jc.
                    I hope I don't have the same problem with OEM rockers. that would be unfortunate. I think if the same one broke twice I'd for sure be doing a head rebuild.
                    i've seen the MM ones as well, maybe they're worth a try if the issue repeats itself. that would suck.
                    "touch wood"... lol
                    • digger
                      • Nov 2005
                      • 6194
                      "touch wood"... lol
                      best chance of breaking them in together if rockers and cam are new
