Ideal exhaust diameter?
  • Burnera
    • 137
    Here's another one for the hive mind.
    For a non-turbo M20, what's the ideal exhaust diamter?
    Does going catless change that?
    If passing emissions is no problem (and it isn't since there is no test in my state) what set up would you shoot for?
    The only thing i don't want is an obcenely loud exhaust.
    Only reason i want to replace what i have is that it's quite rusty.
    • 34844
    if it's relatively stock I'd go 2.5"
    highly modified (200hp minimum) I'd start considering 3" with good headers (not ebay crap).
    loudness is mostly defined by the type, quality and number of mufflers/resonators/cat that you have, rather than exhaust diameter.
      • 37833
      I'd vote 2.5" as well.
      Grover Beach, California
      BimmerHeads.com
        A two into one collector at the down tubes and a single 2-1/2 pipe back to a free flow muffler is more that adequate for a normally aspriated M20 engine. The noise level will be a function of what muffler you choose to use.
        • Adrian_Visser
          • Jun 2006
          • 2823
          Really? Alot of s52 guys are running single 2.5" exhausts. I thought single 2.25" was better for an N/A relatively stock M20.
          '89 Alpine S52 with goodies
            • 34844
            that's because BMW guys like to run exhausts that are too small.
              • 37833
              Piping size will also change the noise level.
              BimmerHeads.com
              • 619E30
                • 1753
                If you want it to be quiet, go 2.25" but I run a 2.5" and I'm, satisfied
                Originally posted by audiquattrot
                bimmers b4 b*tches....remember that.
                1990 Alpinweiss 325i - secret 500whp build
                2000 Audi S4 B5 Laser Red
                1990 Nissan 240sx - Drift Missile
                2006 CBR600RR
                • Danny
                  • 14216
                  You're talking out of your ass.
                  • Burnera
                    • 137
                    With subaru engines that are N/A, if the exhaust gets too big, you completely lose low RPM torque. That's something i'd like to avoid, but i dunno how the M20 behaves really.
                    I6 vs H4, 2.5L vs 2.0L, they are different engines completely.
                    • digger
                      • Nov 2005
                      • 6192
                      thats if you get headers that are too large, but from cat back pretty much won't influence that
                        • 34844
                        barely. mine's 3" and just as quiet as it was with the stock diameter/dual pipes.
                        • Adrian_Visser
                          • Jun 2006
                          • 2823
                          What resonator/muffler combo are you running?
                          My 2.25" single exhaust with who knows what cat and who knows what resonator into a magnaflow 14815 muffler is loud as fuck, mostly because of the muffler I suppose but still... Don't you lose a shit ton of low end torque with an over sized exhaust?
                            • 34844
                            that's because you're using a shitty magnaflow muffler ;)
                            I have a borla as a center resonator/muffler and a dynomax turbo as a rear muffler. it was a bit louder at first but quieted down as it broke in. I also have a magnaflow ceramic core cat, which sucks, but for different reasons than their mufflers (nice tips, tiny inlet, bad noises).
                            as far as "oversized" exhaust - you lose torque with bad headers (or improperly chosen for the powerband). read this to find out why..
                            in any case 3" isn't much "oversize" (and 2.5" certainly isn't). definitely not for an S52...
                            • lateracer
                              • Sep 2009
                              • 302
                              I have 2.5 from the (stock) manifold running through a glasspack with a turn down behind the rear TA. My friend runs the same set up, but with a 2.25 pipes. Both are loud, mine is slightly louder, but neither is too loud...but they're close. Usually around 90 db at the listening stations on the track.
                              Quiet enough to talk to someone in-car while it's idling and driving around 3500 RPM. At WOT I can still hear people with the in helmet radio, but if they're in the passenger seat it's impossible.
