i need some thought's on piston set up in by b27
  • KillaCam
    • 2103
    i am thinking of buying 11:1 pistons and running a stock 731 head on top.
    what do you think. it will be a stock block and everything.
    i'm not going to boost or anything on this engine
    Originally posted by E30_(1st Musk)_
    HONDA IS WHERE EVERY TREND DIES! .
    24v swap Oil Pan..F/S
    • 34844
    make sure you run some sort of aftermarket cam, or you'll have detonation up the wazoo on pump gas.
    also with said cam, check/cut valve reliefs.
    • ForcedFirebird
      • Feb 2007
      • 8300
      x2.
      Stock cams are not known for overlap lol.
      john@m20guru.com
      Links:
      • lennon
        • Jun 2008
        • 1416
        i would get an 885 head and pistons made for whatever rods/crank you're using (eta i assume) + the 885 head. it has bigger valves and dual valve springs already.
        • KillaCam
          • 2103
          well i got a 731 head already for cheap cheaper than a 885 head and i ported and pollished it both sided and i'm going to runn all the 'i' stuff. I can get bigger valves and stuff and a after market cam but if i ran a aftermarket cam would i have valve clearence problems?
          • 5KWattson
            • Apr 2009
            • 809
            24v ftw
            "God created turbo lag to give V8's a chance" Taylor D.
            • KillaCam
              • 2103
              i don't know what denotation is and what do you mean by check/cut valve reliefs
              • KillaCam
                • 2103
                Originally posted by 5KWattson
                24v ftw
                i could go with 24v and i was thinking about it i found a 328is stick crashed for 400$$ but i didn't have $$$ or space
                • 5KWattson
                  • Apr 2009
                  • 809
                  ahhh i wanna do a m52 turbo build
                    • 34844
                    24v ftw
                    thanks for your poignant and insightful post. Please share more of your wisdom with the forum.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      Junkyards don't know the difference between an "i" and "e" head, but if you swap the "i" springs and have the head drilled for the extra cam bearings, at least you will be able to rotate the motor higher - even though the 731 head runs out of steam after 5k RPM.
                      Detonation is how a diesel operates. Instead of having a spark plug, they rely on compressing the fuel SO much that it will actually "self ignite" from the heat generated by the compressing of the air/fuel mixture. In the case of a gasoline engine, this is very bad because if this happens it means that it will be happening TOO early and forcing your piston down when it should be moving up - possibly damaging pistons, rods, rod bearings and in extreme cases, the crank.
                      No offense, but if you are talking about putting custom pistons in your engine and are balking at $400, you have a long financial road ahead of you. I have been building engines of all kinds, makes and sizes, and it's not uncommon to spend $400 on the pistons alone, bearing packages alone, gaskets alone, machine work alone etc - never mind being able to re-build an engine with custom parts to boot for that kind of budget.
                      Maybe I should ask the same questions as I ask my customers at the shop, and on my site:
                      What's your budget? What parts you already have? What's your abilities/experience/tooling? What's your power goals?
                      john@m20guru.com
                      Links:
                      • KillaCam
                        • 2103
                        ok so this is telling me i should just put the 731 head on with stock eta pistons. I was looking to buy early euro eta pistons for 150 bux there raised flat top 11:1. or should i go with seta dome pistons. I want to get the most power from stock stuff.
                        • lennon
                          • Jun 2008
                          • 1416
                          You need to do way more research and also pick up lots of basic engine knowledge before you attempt to do any of this work to your motor. How can you expect to be successful at putting together a custom engine if you don't even know what "valve reliefs" in pistons are, or any of the other stuff you're asking us? I actually know about this subject but I had to stop myself from even trying to explain it to you, because I'm pretty sure there's no point.
                          • briansjacobs
                            • 1278
                            11:1 compression on pump gas. Motor will last you a week. I was running 11:1 in my old 2.5 and would get detonation on 110 octane. It was not until I ran 110 octane that the motor was safe to run.
                            And you will spend the better part of $800-$1000 on the pistons.
                            Brian Jacobs
                              • 34844
                              didn't you say that was with a stock cam though? that wouldn't surprise me. at 11:1 I'd be looking at a schrick 288 or even 304. you'd have to retard it a bit at peak torque but it should be great past 5000rpm.
