87 m20b25 into a 88is
  • rede30
    • 4697
    I just finished up putting a motor from a 87 325is into a 88is. I am not getting spark or fuel. Is there a wire trick I am forgetting about with this early model motor being put into a late model? The only difference I am seeing are the wires that are right next to where the DME and harness connect but I didn't think these provide any signal for the DME to do its thing.
  • 87e30
    • Jul 2008
    • 5676
    As an aside, this is illegal as far as I know.
    I believe it is illegal to swap in an engine older than the chassis. Not that anyone will likely find out.
    I just hate everyone.
    No need for discretion.
    • reelizmpro
      • 9533
      I can't think of anything either. Just an engine swap right? using the 88 engine harness? or 87? I assume you changed the water pump to the later style right?
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • rede30
        • 4697
        Yeah, cooling system is the only thing I could think of. And I did change every cooling thing for the late model style. I used the 87 harness. I could always change it out if need be but I cant think of why I would need to.
        • caliGreen
          • 195
          illegal.? that was the whole point of it and that turbo kit to
            • 37829
            Use the original engine harness!! (Not the 87) Everything will work perfectly.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
              • 37829
              Oh my god, call the cops.
              Grover Beach, CA
              www.BimmerHeads.com
              • Lunner
                • 222
                Is there any difference besides the fuel rail?
                87 325iC 90 325iC 88 325iC 87 325i 87 325iS 87 325eS
                • rede30
                  • 4697
                  yeah, didn't know 87 harnesses were useless. Tossed the 88 harness in and drove off. I also had to change the starter and fuel rail harness. This motor has a lot more oomph than the motor with 441K had.
                    • 37829
                    87 harness is perfect for an i swap in to an early model e though! :)
                    Grover Beach, CA
                    www.BimmerHeads.com
