in the middle of timing belt swap, need help
  • 2.5-12
    • Jan 2010
    • 1814
    the Slush-o-matic sprayed ATF all over and had a bit of a coolant gasm when she started up, next up:
    remove slushbox, replace with proper Getrag 260
    remove 3.73 and replace with proper rebuilt S3.73 that is waiting patiently on the shelf.
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
    • Sagaris
      • Sep 2009
      • 2243
      congrats on the successful timing belt change. You need to document your trans swap real well so I have yet another guide to consult when I do mine :)
        • 34847
        you really don't need to remove the radiator for the t-belt change. I never have.. saves a lot of time, especially with an automatic.
        at least now we know why it takes you longer to do a t-belt than a clutch job.
        • 2.5-12
          • Jan 2010
          • 1814
          I convinced myself it was time to put in the Getrag that has been sitting next to my car, it was just too lonely looking. also, time to put in the S3.73 :)
          • 2.5-12
            • Jan 2010
            • 1814
            I took 40 pics or so: http://picasaweb.google.com/EMTtech/ICTimingBeltChange# sand down the contacts on the Distro cap -- made a world of difference. the tensioner was the only even remotely confusing part of the swap.
            • 2.5-12
              • Jan 2010
              • 1814
              I started early on the 525 belt (motivated and dyno took less time)
              I got through the first bits no problem, I am stuck on that toothed gear on the crank. I have doused it in PB blaster, pryed it from the back and tapped (as hard as I can with 1" of working space) it with a hammer. nothing, doesnt budge.
              any clever tricks? I left it sitting with a shop towel soaked in PB blaster on it and I'll try prying it again tomorrow but I would like to know if anyone has advice.
              • 2.5-12
                • Jan 2010
                • 1814
                525i timing belt done, thanks all.
                2 to go. 85 B27, 89 B25.
                • 2.5-12
                  • Jan 2010
                  • 1814
                  89 B25 done as well, took lots of pictures, the belt on that 89 was very nearly toasted. cracked to hell. I'm amazed the BMW branded belt didnt say made in east Germany on it.
                    • 34847
                    you mean West Germany? ;)
                    • 2.5-12
                      • Jan 2010
                      • 1814
                      yes, ooops :oops:
                      • Farbin Kaiber
                        Lil' Puppet
                        • 29502
                        Yes, a headset wrench works wonders for fan clutches, and it's usually way cheaper than a specific auto tool anyway.
