All the major parts for my 2.8l have arrived.
  • Jordan
    • 12913
    I should be bringing the block and rotating mass to the machine shop this week.
    Block will be bored out 1mm (85mm) Magnafluxed, and decked.
    Complete engine rotational mass will be fully balanced.
    All new everything :) The pistons are 85mm 9.5:1 Forged JE's.
    https://mtechniqueabs.com/
  • 318driver
    • 1714
    Awsome. I was wonderin what your plans were next.
    What do you do for a living jordan, in order to suport all these mods?
    90 325is
    IE stage 3s and refeshed m20....
    • Jordan
      • 12913
      I live at home, although this is soon to change.
      I work at a GM dealership, in the detailing department. I am responsible for the paint restoration on each and every used car traded in (cut and polish add nausea) I also deliver parts to bodyshops and other dealers as needed, and on occation shuttle the customers around while their cars are in the shop.
      Aside from that see those banners up top? Those pay for the hosting and then some. Not nearly enough to compensate for the time I invest into the forum, but it helps.
      Also I work on alot of e30's in Corvallis, my standard labor rate is $25/hr for that.
      • Brew
        • 3060
        I'm curious as to why you went this route as opposed to an M/S50. What have the parts run you so far?
        By that compression ratio I'm guessing that you're sticking NA?
        '91 318is
        • Jordan
          • 12913
          Yes NA.
          I like the m20 for what it is... it belongs in the car. When all is said and done I will have about $2500 into the motor.
          This includes all my previous headwork, and all the labor on the head/bottom end.
          • Brew
            • 3060
            Not bad at all for what you'll have as an end product. Obviously it helps a whole lot to do the work yourself.
            '91 318is
            • Chris E30 Cab
              • 866
              Parts look great :) and I'm lookin forward to the results!
              You might want to check with Fred on those Total Seal rings....he had some issues with them.
              • Jon325i
                • 6934
                Ok....1mm overbore: check.
                What about the crank....Eta or TD?
                With the compression you chose, a sport cam and some porting to the head, that ought to make for a smooth engine.
                Jon
                Rides...
                1991 325i - sold :(
                2004 2WD Frontier King Cab
                RIP #17 Jules Bianchi
                • Jordan
                  • 12913
                  Using a eta crank.
                  • matt325is
                    • 409
                    I'm glad everything is coming together! Our cars will be even more alike! I'm very curious to see how much power you will get out of it, my NA 2.8 was around 155whp, with small other mods... Anyway, can't wait to see it run, any plans to come to the next PacNW picnic?
                    matt
                    • herragge
                      • 361
                      very nice looking parts! definetly helps if you install everything yourself. Hope all goes well with the install.
                      • Mystikal
                        Wheel Fitment Expert
                        • 9602
                        Seems rather low, doesn't it?
                        • niq_nak
                          • Apr 2004
                          • 422
                          very nice. i feel the same way about the m20 in the e30 and intend to go this route down the road as well.
                          how come u went with 2.8?
                          • Jon325i
                            • 6934
                            The 2 valve per pot head is a real bottleneck....can't expect too much in the way of gains. Maybe with some kind of piggyback set up for the ECU or a MAF to squeeze out a few more BHPs.
                            Jon
                            Rides...
                            1991 325i - sold :(
                            • aaron_silva
                              • 1785
                              Does seem a bit low. I saw a stock 325i with a MAF run 145 to the wheels.
                              Aaron
