FAn space question
  • CrazyB
    • 420
    FAn space question
    I am doing my timing belt and water pump this weekend and wanted to convert to electric fan also.
    I will be removing the dead AC system. I was wondering how wide can I go for a pusher fan and how wide of a puller fan can I fit on the car?
    AutoCross Photos!!https://picasaweb.google.com/eugenes18t
  • CrazyB
    • 420
    Also anyone know any fan I can buy at a local auto store that will work.
      • 34839
      16" fits either way
      • CrazyB
        • 420
        But what thickness most local stores they are 3.5 inches in the center, will that fit up frnt with condenser removed?
          • 37832
          Don't buy a shitty auto parts store fan. Keep stock or buy a Spal.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
            The best (and easiest) solution is a 16" SPAL pusher fan mounted in front of the radiator. You'll need a lower temperature thermo switch to operate the fan. With a standard 80C thermostat a switch that trips at 82-82C is just right. A fan rated at 2000CFM or more will do the job nicely.
              • 34839
              I don't get the obsession with Spal. There's tons of aftermarket fans out there. Look in a summit or jegs catalogue.
                There are other good fans out there, but SPAL has earned its reputation as a maker of a quality product.
                • CrazyB
                  • 420
                  This is the fan i was thinking of going with, after measuring the front, looks like when ac is out I have almost 5 inches of room to play with
                  • E30Gus
                    • Jun 2008
                    • 781
                    Can't you also use the stock electric fan on the car with a thermostat/switch change to a lower temp?
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      What CFM does the stock aux fan push on Hi anyways?
                      '89 Alpine S52 with goodies
