Injectors all popped out...WTF PO YOU SUCK!
  • Dsobes
    • Jun 2010
    • 34
    Well it started to poop out while I was driving...Gas could be smelt. I pop the hood. The fuel rail was just chilling there, the injectors all popped out, fuel just spraying onto the manifold... Dumb ass before me didn't screw it down. Is there a way to pop them back in without taking off the intake manifold? Also, the fuel rail hits the thermostat housing. Did this jack ass put it on backwards?
  • E30_fiend
    • Apr 2006
    • 7348
    He quite possibly could have installed it backwards but its kinda hard to do that. The fuel rail is held down with two 10mm head bolts that thread into the intake manifold. You dont need to take the manifold off but you DO need to take the valve cover off to make things easier. The injectors should stay put without the bolts on the fuel rail but they wont stay put for long. You need those bolts to hold the rail in place.
    I hope that helps
    • KillaCams
      • Mar 2008
      • 998
      Holy shit that's scary, gas spraying onto a hot exhaust manifold what a dumb ass the prev owner is for doing that. At least you caught the problem before your car burned down or something
      • Dsobes
        • Jun 2010
        • 34
        I was sweating bullets.
        • Dsobes
          • Jun 2010
          • 34
          Okay So I took off the valve cover gasket, I still can not get the injectors back in! I've started to remove the intake manifold because I can't squeeze those puppies down in there. This is really frustrating. Maybe the gas made the seals swell?
          • SoopaGhetto
            • 573
            nah, just rub a little bit of oil around the seals to get them slide in easy. my friend didnt listen to me and ended up chopping his injectors up cuz they snagged when he forced them in with out some lube.
            • Dsobes
              • Jun 2010
              • 34
              Okay. Thanks. I'll try that. The valve cover defiantly was in the way. Intake is mostly off... Time to put that back on. I'm much more familiar with the m50, this engine is...sort of confusing for me thank you for the tip! My mom keeps telling me the cars a POS and I keep telling her the previous owner is the pos lol. This kinda proves it.
              • CorvallisBMW
                Long Schlong Longhammer
                • 13039
                Lube the o-rings with either some oil or WD40
                • SoopaGhetto
                  • 573
                  lulz
                  yea i hate when people tell me my car is a pos
                    • 34839
                    you definitely don't need to remove the manifold to do injectors. done it many times..
                    • e30rapidic
                      • 2167
                      ditto. use motor oil to lube up the o-rings and they will slide down much easier. Make sure each injector has the clip to secure the injector to the rail...although it sounds like yours are clipped.
                      Also my fuel rail has 4 10mm bolts holding it to the manifold, not 2.
                      '87 325ic, powered by S50.
                      • lonestar22
                        • Aug 2005
                        • 417
                        always use lube
                        Originally posted by Lof8
                        Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.
                        • blueapplesoda
                          • Dec 2005
                          • 1904
                          yes. don't like rips and tears.
                          • jaywood
                            • Jul 2010
                            • 4528
                            Take off the electrical plugs that plug into the injectors. You can now see that there are 4 bolts attaching the fuel rail to the intake manifold. Wipe some engine oil into the little o-rings at the end of the injector and pop the injectors back in the hole. Tighten the 4 10mm bolts and you should be good. You will probably be missing most of the bolts. It's a pretty snug fit so it doesn't have much play.
                            Sorry to bump this thread. I was looking for where to buy intake manifold gaskets and this came up.
                            • llll1l1ll
                              • 782
                              Oh, those extra two bolts is probably why I couldn't get my injectors out.
                              Me: "I can't wait to redline my car!"
                              Mark: "Didn't you just break a rocker arm?"
                              Me: "Yeah, I don't think I've learned my lesson."
                              Mark: "You never will."
