my car is being major PITA this week... little help
  • blocke
    • 1305
    #31
    Originally posted by ubernasty
    This the problem for the symptoms?? 3 relays next to power steering res look fried...
    I would think if they were all totally fried, it wouldn't start at all.
    You can jumper the fuel relay, and I think the main relay..see if that clears things up. Then you would know relays for sure.
    Parts Wanted
    The Never-ending Resto Mod
    • ubernasty
      • Jan 2009
      • 2749
      #32
      how do you do that?
      i've heard about jumping the fuel but i don't know if thats a great idea to jump the main, but i'm not sure.
      • payney8
        • Jun 2007
        • 899
        #33
        Originally posted by nando
        it probably jumps around because your car has air in the cooling system. you lose power because the coolant sensor is a primary source for calculating the amount of fuel to be injected. the O2 is just a minor correction factor, for the most part.
        Doesnt the coolant sensor only run corrections at partial throttle? How does the car run at idle/full throttle. I believe that at no/ full throttle the car runs of 2d Maps. Is that true nando?
        Also id be resetting the dme. That fixed my bad idle problem when my vac line was left of :S. And there are two sensors as stated before one with 2 pins is for the motronic that also runs your gauge till 1/4 temp. Then the secondary sensor switches stopping the cold start on the motronic and running your gauge from then on. I had an issue with it always running rich due to my sensor being faulty.
        • ubernasty
          • Jan 2009
          • 2749
          #34
          Your speaking a different language that I would love to learn about but unfortunately know nothing about right now.
          It doesn't stay running long enough to drive now. When I limped it home the temp gauge was bouncing all over at different speeds and throttle. When it would bounce to normal for a second or two it did run fine. But then it would jumped again and even if i gave it full throttle it didn't want to accelerate and just stuttered.
          I barely made it home and it was getting progressively worse. I then hooked the ground back up and now I'm where I'm at now.
          • dsobering47
            • Oct 2007
            • 697
            #35
            So,
            1) Your temp gauge is bouncing everywhere (The whole range or just one part?)
            2) Theres a strong fuel smell (where?)
            3) The car doesnt want to idle? Or when you give it gas, you have problems?
            Stop typing every little thing that happens and focus on important stuff (coolant temp, fuel smell). Go over your engine bay and examine where those "hacks" were. Disconnect your battery negative and let your DME reset for 15 minutes. Sounds like you have multiple problems and youre trying to fix them all with one repair....you gotta take them one-by-one.
            • dsobering47
              • Oct 2007
              • 697
              #36
              BTW sounds like your car it starting to overheat, if your hoses are really pressurized and the temp calms down with speed (air moving over your radiator)
              • HarryPotter
                • Jan 2010
                • 3642
                #37
                did you bleed the system properly?
                John F. Kennedy
                • ubernasty
                  • Jan 2009
                  • 2749
                  #38
                  Originally posted by dsobering47
                  So,
                  yes all those are correct.
                  I'm typing everything little thing that happens to give a detailed description. This isn't a random "my car won't run" thread. It was because i drove around on a disconnected ground from my oil pan to frame rail unknowingly... which i assume would have something to with my problems specifically.
                  And..?
                  Bleed what, the coolant system? The coolant system wasn't touched so probably doesn't have anything to do with the problems I described.
                  • payney8
                    • Jun 2007
                    • 899
                    #39
                    And..?
                    Reset the dme. Check your fuel line/rail/fpr and go from there.
                    • ubernasty
                      • Jan 2009
                      • 2749
                      #40
                      Will do, i'll get back later.
                      • ubernasty
                        • Jan 2009
                        • 2749
                        #41
                        still won't stay running, smells of gas very strong.
                        • SpecM
                          • Oct 2005
                          • 4531
                          #42
                          since you had the oil pan off, I would say that there is a possablility of a vaccum leak
                          just a guess
                          1989 cirrisblau-metallic 325i
                          • e30huh
                            • 216
                            #43
                            check your oil cap
                            are you up in the ghetto of B-more?
                            • ubernasty
                              • Jan 2009
                              • 2749
                              #44
                              just a guess
                              Alright i'll check that out.
                              Originally posted by e30huh
                              check your oil cap
                              Baltimore county.
                              • blocke
                                • 1305
                                #45
                                Any progress?
                                Parts Wanted
