Bosch Spark Plugs
  • CasanovaE30
    • 30
    Bosch Spark Plugs
    Hey guys I bought Bosch Plantinum +2 Spark Plugs cylinder 4 complete oil fouled the plug after a month, should I put in a different spark plugs in because it didn't do that when I had normal plugs in? But I know an engine rebuild is on it's way.
    Put that in your pipe and smoke it!
  • blocke
    • 1305
    If the plug is getting oil fouled, it will make no difference what kind of plug you put in. Its either worn piston rings, valve guide seals..etc.
    But no other kind of plug will stop oil fouling.
    Parts Wanted
    The Never-ending Resto Mod
    • Atreus
      • 1846
      just get the plain bosch w8lcr or whatever, or the NGK comparable, copper core, single plug, none of that fancy stuff...
      1991 325iC - Mauritsblau sumthin metallic blue. DEAD
      1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
      1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
      1991 325iC - Calypsorot Metallic
      1994 540i - Granitsilber
      Originally posted by scabzzzz
      I've had blunts cock in my mouth, but I'm not gay.
      • whodwho
        • Jun 2008
        • 1547
        A hotter plug may help from fouling so quickly until the rebuild.
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          • 34844
          stop putting platinum plugs in your car.
          • E-Thirty
            • 1331
            Listen to this guy.
            Do you feel like something is trying to penetrate your butthole?
            • 36brua
              • 689
              sparkplugs to try as suggested by forum members
              Bosch WR8LC superseded W8LCR ....or NGK ZGR5A
              My CA legal M60 swap
              The happening in our garage
              • CasanovaE30
                • 30
                If my car didn't burn oil in cylinder 5 the spark plug wouldn't have fouled, so i don't see anything wrong with platinum plugs.
                • SpecM
                  • Oct 2005
                  • 4531
                  seriously, the car will run better on copper plugs, fouling or not
                  1989 cirrisblau-metallic 325i
                    • 34844
                    okay
                    • payney8
                      • Jun 2007
                      • 899
                      lol
                      • JTDay
                        • Dec 2009
                        • 521
                        I prefer NGK plugs. The e30s single coil ignition system cant keep up with platinum/iridium plugs. The oem reccomendation of a copper plug is designated for a good reason. You should replace your valve stem oil seals.
                        Past: 1987 325iS, Bilsteins - HR Sports
                        Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
                        2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
                        • xwill112x
                          • Jan 2009
                          • 4236
                          i run bosch +4's in my m42, they last forever, and work better than the +2's, idk why everyone hates on em
                            • 34844
                            good for you
