Ignition Cutting Out Randomly
    So this started the other day. Car drove perfect the night before, came home and parked next day car started right up to head over to a friends house a few blocks away, after a minute of driving the engine cut out while driving in gear. The tach dropped down to zero. So I put her in neutral and tried to start it while moving, nothing. So then I got down to about 10 miles an hour, put her in first and dropped the clutch and she started up. This is the first time anything like this has ever happened while ive owned the car btw. Then got to my friends house and after and hour I tried to start the car and it would turn over but just wouldn't fire. So then I got another push from my friends car and bump started it and it ran. But then stalled again. Noticed my gas was pretty low and my gauge is pretty inaccurate so we put some gas in the tank and it fired up with the starter and was good for the rest of the day. Now today I did about 4 hours of highway driving hitting up scrap yards and such. And again I had the problem while going down the freeway. The tach shot down to 0 rpms while the in gear. So I pulled over, let it sit for a few minutes and then it started up normally.
    So what could be the reason the ignition just stops randomly sometimes now. Im guessing I should replace the distributor and cap. But any other places check?
    Thanks!
    Btw. I did a pretty crafty lip job from a volvo front airdamn like the one in this pic. Pics installed tommorow probs.
    Your fuel pump is going out.
      yep thats what it sounds like
        Would the gauge cluster cut out like that if thats the problem?
          Yes, no fuel -> car dies -> motor isn't sending a signal to the tach -> dead tach.
            Originally posted by danny View Post
            yes, no fuel -> car dies -> motor isn't sending a signal to the tach -> dead tach.
            <333
              If the car is in gear and moving and you see the tack go to zero when the engine dies the cause will be something that is causing the DME to shut down. A bad CPS, bad main relay, flaky fusible link, or even a bad DME are possibilities.
                I agree with Jim, my brothers car would have a similar symptom where as you're applying throttle, it would cut out but then come back on. We came to the conclusion, and correct me if I'm wrong but the third relay from the main relay, I believe is the o2 sensor relay, was loose. We pushed it in fully and the problem went away. I'm not sure if it is applicable to your problem but that's what we did!
                FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
                Originally posted by scabzzzz
                I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
                1989 325i - Project/weekend driver
                2002 325i - DD
                2005 Suzuki SV650 - Toy
                  Thanks a bunch guys. The problem has seemed to go away but im still gonna double check everything.
                    test the car with a different dme.
                    i had a similar problem.
                    through some parts at the car
                    problem stayed
                    swapped a dme with a known working one
                    and problem solved.
                    Project
                    Parts for Sale
                    Feedback
                    YouTube Channel
                      Sounds like A main relay issue...
                      @Zakspeed_US
                        The symptoms you described can ONLY be the main relay.
                        Wiggling it might help for a minute, but the contacts inside crap out, so long term, replace it.
                        Closing SOON!
                        Thanks for 10 years of fun!
                          ^ agreed
                          i replaced mine and it still did not fix it.
                          the 3 relays
                          engine ground strap
                          crank position sensor
                          multimeter tested throttle position sensor
                          new dme temp sensor
                          new cluster temp sensor( while i was there kind of thing)
                          o2 sensor( the orginal one was installed)
                          fuel pump
                          fuel filter
                          rubber fuel lines
                          rebuilt and calibrated fuel injectors
                          ended up being something wrong with the orginal dme
                          robert from e30 motorwerks hooked me up with a spare dme he had and it fixed the problem.
                          Project
                          Parts for Sale
                          Feedback
                          YouTube Channel
