Want to run a 1.3 motronic ecu on a 325e
  • The Humjet
    • Jun 2010
    • 528
    Hello
    What I have at home is a 323i engine and gearbox but no loom or ecu.
    And i also have a 325e donar car with a screwed up autobox.
    What I was thinking of doing is a hybrid of the best bits so 325e block with a 323i head and gearbox.
    Could I connect a 325i wiring harness and run a motronic 1.3 ECU? and then put a W.A.R chip into it and the other cool things like a MAF conversion and ecu controlled thermo fan.
    Or can that all be put onto the normal 325e ECU (motronic 1.0)?
    Yes that can be done. You'll need the AFM, CPS & bracket, and engine harness from an M20B27 engine. You might also have to change a sensor or two for the connections to match the harness.
      • 34839
      you can do it, but basically if it's electrical, it will need to be swapped over. That includes the injectors and all sensors. You also need the 3 bar fuel pressure regulator.
      • The Humjet
        • Jun 2010
        • 528
        sorry but what is a CPS
        • StereoInstaller1
          GAS
          • 22679
          This is where we say "IT RUBS THE LOTION ON ITS SKIN or else it gets the hose again"
          Closing SOON!
          Thanks for 10 years of fun!
          • Kershaw
            • 11822
            crank position sensor.
            i've also seen it called camshaft position sensor.
            AWD > RWD
            • The Humjet
              • Jun 2010
              • 528
              I've never called it that I just call it crank angle sensor which doesn't really matter anyway they both do the same thing.
              I'm getting a bit confused, I'm hearing different opinions. What sensors can I keep and what would need to be changed or added in order to run a motronic 1.3 ecu
              • Adrian_Visser
                • Jun 2006
                • 2823
                Others have forgotten to mention that you will need a harmonic balancer with a 60-2 toothed wheel for the CPS to work.
                '89 Alpine S52 with goodies
                  • 34839
                  you can't keep ANY of the eta sensors. You need everything from a 325i, except the bare engine itself.
                  • The Humjet
                    • Jun 2010
                    • 528
                    ok then instead of going through all the trouble of changing all the sensors and the harmonic balancer couldn't I simply keep the whole eta loom as is, and tune the stock ecu.
                      • 34839
                      yes
