noob question things to check for long cranking & fire up on 2nd start
  • iwantspeed
    • 3164
    Hey guys.
    After trouble shooting some other issues, I have thrown a lot of parts at my car.
    last annoying issue is that intermittently the car will take a long time to crank and will start on the first try.
    other times it will not start on the first try
    but start right away on the second start.
    my theory is,
    that the fuel pressure regulator is on its way out and is slowly letting pressure out.
    on the first crank it builds pressure and on the second start it starts right away.
    new parts
    main relay
    o2 relay
    fuel pump relay
    engine ground strap
    crank position sensor
    multimeter tested throttle position sensor
    new dme temp sensor
    new cluster temp sensor( while i was there kind of thing)
    o2 sensor( the orginal one was installed)
    fuel pump
    fuel filter
    rubber fuel lines
    rebuilt and calibrated fuel injectors
    cap, rotor, spark plugs
    air filter
    starter
    battery
    coil
    things I want to replace to possibly fix this issue.
    • plug leads
    • fuel pressure regulator
    Project
    Parts for Sale
    Feedback
    YouTube Channel
  • Mike
    • 932
    You need to do a fuel pressure test first. It is very simple to do, and the cost of the fuel pressure guage is not very expensive. If you have an 325i, it should make around 43.5psi, at idle. When you shut the car down, it should hold pressure in the line as well. If not, your in the market for a new fuel pump. Some e30's have two pumps, some have one. Search for the details about what setup your car has. Stay away from those chinese ebay pumps too.
    Supatek -noun - your basic know it all
    • iwantspeed
      • 3164
      this e30 has one intake fuel pump.
      thanks for the tips
      Project
      Parts for Sale
      Feedback
      YouTube Channel
      • SocalianSD
        • Jan 2010
        • 152
        Check your injectors also. I had a one that was leaking and flooding the cylinder which was causing my hard start. I had them rebuilt through CruzinPerformance and my car runs like a champ now! :up:
        EDIT - Nvm! I read over the part you said you already have rebuilt injectors... My blunder.
        6287156541_32b0c468f4_z-1 by SoCalian_SD, on Flickr
        • iwantspeed
          • 3164
          still have the same problem...
          Project
          Parts for Sale
          Feedback
          YouTube Channel
          • payney8
            • Jun 2007
            • 899
            Check your line to from your fuel pump to the external connector. Sometimes these can leak loosing fpr after a while and no leaks can be found because it leaks back into tank
            • iwantspeed
              • 3164
              thanks for the tip
              can you be a little bit more specific?
              is it a hose pictured here?
              http://www.realoem.com/bmw/showparts...03&hg=16&fg=15
              Project
              Parts for Sale
              Feedback
              YouTube Channel
              • payney8
                • Jun 2007
                • 899
                http://www.realoem.com/bmw/showparts...81&hg=16&fg=15
                Number 14 or 20 I dont know on the twin pump set up. It's the line that runs from the pump to the external hard line on the lid. It can erode or get loose on the fittings
                • iwantspeed
                  • 3164
                  ok perfect thanks
                  I will check it asap
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                  • iwantspeed
                    • 3164
                    issue still persistent
                    Project
                    Parts for Sale
                    Feedback
                    YouTube Channel
                    • hotballs
                      • 1155
                      replace the FPR
                        Run the fuel system tests in the Bentley. If the FPR is bad those tests will tell.
                        Another possibility that no one has mentioned is intake leaks. Have a smoke test run.
                        • iwantspeed
                          • 3164
                          still struggling with this issue guys
                          Project
                          Parts for Sale
                          Feedback
                          YouTube Channel
                          • digger
                            • Nov 2005
                            • 6194
                            get a good set of injectors, i had a similar problem many years ago and just replaced the injectors.
                            • iwantspeed
                              • 3164
                              injectors are rebuilt stock ones. and i think they are working properly
                              Project
                              Parts for Sale
                              Feedback
                              YouTube Channel
