schrick 288 cam spark plug gap?
  • dkbmxer002
    • Nov 2007
    • 1389
    we are changing the plugs on my buddies m20 car with schrick 288 cams and i was curious if the spark plugs need to be gapped any different? is .31 a good gap for them? would the cam need a change at all from factory gap? thanks for the help.
  • Sagaris
    • Sep 2009
    • 2243
    Do you mean 0.031" (not 0.31") ?If it misses at lower RPM then you will need to close the gap or look into replacing the coil. I run my car at 0.032" gap without any issues on a stock 190k mile coil with a chip and 17# injectors on the stock cam. I can't imagine you will have any issues but hopefully nando will chime in with his experience
    • dkbmxer002
      • Nov 2007
      • 1389
      yea that is what i meant, typing on an iphone quick always makes me fail. thanks, just want to make sure it doesn't change with a cam, i assume it wouldn't but just want someone to clarify for sure.
        • 34844
        run colder plugs, like NGK BPR6ES
        use the same gap as stock
        you don't need a stronger coil unless yours is dead..
        • dkbmxer002
          • Nov 2007
          • 1389
          thanks alot man!
