custom exhausts
  • jaywood
    • Jul 2010
    • 4528
    custom exhausts
    How many of you guys have made your own exhausts? I'm thinking about running 2.5's straight.
    How much piping did you need? I was thinking 2 four foot straight tubes, and maybe a couple 45 degrees.
    Thanks guys/
  • 33xander33
    • 46
    It's not much for performance but I straight piped my 325i and it sounds incredible.
    • brody
      • Jul 2009
      • 334
      It's not much for performance, you are right. You will actually lose power unless you retune your car.
      • e30trooper
        • 11576
        You lose low end tq, but gain Topend response. Depending where you live you will get pulled over.
        • azael325i
          • Dec 2009
          • 1258
          I just went to the Castros shop and they did a great job. I got a spin tech and love it.
          http://www.r3vlimited.com/board/show...46#post3229446
            • 34827
            what? You won't lose torque from a single 2.5" pipe, unless the engine is going lean because it needs retuned (which is what broday was getting at).
            • brody
              • Jul 2009
              • 334
              It doesn't go lean, the power loss come from it going too rich.
                • 34827
                it could go either way depending on what's going on with your exhaust scavenging.
                in my case, the exhaust made the car run 10% leaner because it was scavenging more on the intake stroke.
                it could also read rich if you were overscavenging because it would be sucking part of the intake charge out the exhaust, but that's unlikely on an M20.
                Hoveringuy's M54 went rich with the euro S50 headers. Maybe it's a MAF thing? going into an untuned part of the MAF transfer curve?
                • MonkeyMadness
                  • 3251
                  Where and how much $$$ ????
                  Originally posted by azael325i
                  i just went to the castros shop and they did a great job. I got a spin tech and love it.
                  • Killacortes
                    • 1937
                    So single gains more low end torque? or does dual have a better gain? I have a NV m50 and its all top end. some low end torque gains would be bueno
                    r3v does not fuck around. First you get banned, then they shoot you
                    • azael325i
                      • Dec 2009
                      • 1258
                      Castro's customs
                      North Hollywood ca
                      Ask for chris great guy and prices. He has done just about everything on my car. With the spin tech exhaust system complete was about 400$ which other places wanted 500-600$. It's not to loud too...
                      • u3b3rg33k
                        • Jan 2010
                        • 2452
                        Wouldn't that cause it to read lean? unburned fuel / air mix has extra O2, not less. just like spark blowout reading lean.
                        Ich gehöre nicht zur Baader-Meinhof Gruppe
                        Originally posted by Top Gear
                        Just imagine waking up and remembering you're Mexican.
                        Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
                          • 34827
                          No, there's not more/less torque from single/dual. there's no difference at all, it's all the same after the X or Y pipe assuming it's not too small.
                          • StereoInstaller1
                            GAS
                            • 22679
                            Nope, not true.
                            Larger tubing has less scavenging at lower RPM, THAT is where the torque loss happens. Larger tubing has less exhaust velocity; how could anyone see it differently? Until the RPMs go up to the point where the tube(s) can properly scavenge, larger tubing WILL decrease torque due to less frequent gas pulses causing slower exhaust velocity. This is not debatable, it is fact.
                            It is all about the resonant frequency. Smaller tubing has higher Fs, even if it is dual, with or without Xs or Ys.
                            Smaller tubing also means less cabin drone (that higher Fs again), which is why BMW did it on their higher performance models, not to mention better ground clearance.
                            IF your goal is street driveability and torque, do dual tubing. If your goal is high RPM performance, go large single tube. Either way, match your exhaust to your useage.
                            Closing SOON!
                            Thanks for 10 years of fun!
                            • Killacortes
                              • 1937
                              Nope, not true.
                              street driving and torque is def the goal. The guy who owns exhaust pros here close to where i live recommended dual 2 x pipe with dual in dual out magnaflow muffler. does that seem about right? or is dual 2 inch too small
