Cracked head?
  • KillaCam
    • 2103
    Cracked head?
    How often do you guys ear about cracked heads from over heating?
    Idk if I have a cracked head or warped head?
    I've redone the head bolts and changed the gasket since the over heating and oil is still mixing with the water!
    Could the block be damaged ?
    Originally posted by E30_(1st Musk)_
    HONDA IS WHERE EVERY TREND DIES! .
    24v swap Oil Pan..F/S
  • reelizmpro
    • 9558
    Did you have the head checked out before reinstalling? The head is more prone to damage since it's aluminum. Probably have a crack somewhere. Some shops use a dye to find exactly where. Block is probably fine.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • KillaCam
      • 2103
      Ya tomorrow I am taking it to a local shop
      Just wanted to get some opinions since the dude was convinced before I even walked 2 steps in that it was cracked
      • reelizmpro
        • 9558
        Well yeah, it's a 20+ year old aluminum head. You would have been lucky if you got away with just a bad head gasket. Should have had it checked while it was off.
        88 M3 - LACHSSILBER
        • KillaCam
          • 2103
          Idk I wiped it down and saw no visible cracks but idk about this never ha this prob
          But I'll just see what he finds out and go from there
          • Kershaw
            • 11822
            high pressure oil will get into cracks you cant see.
            AWD > RWD
              • 37833
              Did you even have the head resurfaced when you did the gasket?
              Grover Beach, California
              BimmerHeads.com
              • KillaCam
                • 2103
                No do you need to resurface the was everytime you do a gasket change ?
                • Kershaw
                  • 11822
                  its preferable.
                  AWD > RWD
                    In most cases, yes. At the least you need to have a shop check the head for warp and cracks.
                    • KillaCam
                      • 2103
                      Do you have to do it even if the head gasket didn't blow....like if you just swapped heads ?
                        A used head should always be checked. The only time that its is safe to install a head without having it checked is in the case of a brand new head or one that has just been rebuilt.
                        • Uliv1c
                          • Jul 2010
                          • 43
                          I had the same problem., Iam looking for an engine., my was warped also ., after replacing all new parts .. Look for a good reputable shop...
                          • E30is90
                            • Jul 2010
                            • 107
                            There's a place in Florida called Clearwater Cylinder Head, which will do a complete rebuild of the 885 for a flat $500 with a $25 two-way ship fee. Just used them for mine a month or so back. Thought the price was reasonable for a complete rebuild. As it turned out, my camshaft journals were pretty well ground down, so I opted for a brand new stock camshaft and a brand new casting. After all was said and done I wound up with a brand new head costing me $798. As a daily driver, for me it was worth it. The car sounds and feels like it did when I drove it off the dealer lot 21-years ago. I almost forgot what the car sounded like after years of rocker tapping.
                            over 240,000 miles served
                            original owner since Oct. 31, 1989
