Unichip and HFM installed and tuned, dyno results.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    Awesome work Jordan, glad to hear it's all running strong.
    • Jon325i
      • 6934
      Hmmm....nearly the same power as an M30B35 and no weight penalty. Sounds like a winner to me :D
      The numbers are also quite similar to a chipped M50. Good info to compare with.
      Nice results Jordan :up:
      Jon
      Rides...
      1991 325i - sold :(
      2004 2WD Frontier King Cab
      RIP #17 Jules Bianchi
      • japspecvr6
        • Apr 2005
        • 602
        wow......
        M52 |S52 Cams|E36 Rack Swap|GC Coilover Kit |. . . . . . . . . More To Come
        • RCWells
          • 3589
          Nice man.
          Curious what a stock 2.5 puts out on the dyno?
          Also, what else you got planned to pick up the few extra?
          [THE 501 club - Founding Member]
          • matt325is
            • 409
            Originally posted by RCWells
            Nice man.
            About 138whp and 137wtq, depending on engine and atmospheric conditions, as well as type of dyno.
            matt
            • RCWells
              • 3589
              Wow, that is a pretty substantial difference then. Well worth the price of admission.
              • japspecvr6
                • Apr 2005
                • 602
                it only puts that amount out
                • Mitch M
                  • 881
                  Re: Unichip and HFM installed and tuned, dyno results.
                  Originally posted by Jordan
                  Right now the timing is adjusted to -8º around the area of peak tq to prevent detonation, and similar retard throughout the main power range.
                  8 deg off the stock map or 8 deg BTDC?
                  Is your engine 10.2:1 or 9.5:1?
                  • AdamF 88iS
                    • 2051
                    Nice man.
                    matt
                    Yea thats about right.
                    For what it's worth, the last crazy M20 we put together had a crazy cam, an extrued honed intake manifold and an M30 AFM (no unichip) in addtion to what Jordan has on his build and it put a little over 180 to the wheels. Something to think about for the next steps Jordan; I bed you could break 190 at the wheels with a cam and extrude hone.
                    Adam Fogg- '88 M3
                    Common sense- It's the new 'gifted'
                      • 34839
                      he already has a cam.. and I still think extrude hone is a big waste of money. but that's just IMO... ;)
                      • Jordan
                        • 12912
                        8º retard off the stock map AFAIK. 10.2:1
                        I have a 274/274 11.5mm lift Schrick. I also have a port matched IM, which no doubt makes a difference.
                        Working against me is that stock rubber intake boot accordian, stock TB, and stock exhaust manifolds. I'm going to do a nicer header setup on the car once I am in Texas, and make a custom pipe to replace the accordian boot. I might also go with a BBTB. Thats about all I'm going to put into this motor anytime soon if at all.
                        https://mtechniqueabs.com/
                        • ultima
                          • Aug 2004
                          • 354
                          Wow that is awesome. Nice work man. Why don't you custom make yourself a set of ITB's? Unless you have the money to pay for a set. That would definitely help with your intake. :D
                          • C ///M
                            • 1040
                            You said your JE pistons were 9.5:1. Did you shave your head?
                            332iS R.I.P.
                            • Jordan
                              • 12912
                              No, JE fucked up.
                              • rwh11385
                                lance_entities
                                • 18403
                                Jon
                                Yeah, nice work. I think the biggest plus is the nice strong healthy torque curve, not the HP figures.
