Where to rent Valve spring compressor?
  • MaksV
    • 1042
    Any clues guys? I need to rebuild a M20 head and need to remove the valve springs, who rents a tool for this?
    Thanks
    CHEAP REBUILT INJECTORS
    Need Quality Brakes? BimmerBrakes has it!
    For anything Else go with BluntTech!
    Why not let the shop that is going to work over the head do it?
    • MaksV
      • 1042
      cause there is not shop going to work over the head do it. The head is fine, except its getting a new cam and gaskets. I see no reason to pay a shop to do this. I need a place to rent the tool so I can do it myself.
      • whodwho
        • Jun 2008
        • 1547
        A lot of auto parts stores loan tools, at least out here in the West.
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        • MaksV
          • 1042
          ya but this is a specialized expensive tool generally. but your right, I should check autozone and orielly out first.
          • McGyver
            • 4636
            ^like he said. i generally like advance auto better though.
            • whodwho
              • Jun 2008
              • 1547
              I have borrowed them before, you do have to leave a deposit it was like $100-125 or there abouts i believe.
                • 34844
                you can buy one at sears for $20.
                  If that is all you are going to do there's no need to remove the valves.
                  However, if the head has 100k or more on it I'd have it checked for warp, the valves ground, new seals, and new guides if they are worn (and they probably are).
                  • MaksV
                    • 1042
                    It is getting new seals - basically all new rubber, best I know the head has about 80K on it, I will be checking for warp this weekend, but the guy I got it from said there was none, obviously I need to check, but to replace valve seals I need to remove the spring.
