The 6 year old Pelican article photo doesn't provide me enough info, how do I know when a cylinder is at TDC? Should the exhaust side cam lobe be pointing straight down? I'm using the old "put it in 5th gear and push it" method.
Also, there should be a little play in the rocker arm up and down right? Because I'm adjusting the gap where the up and down play is at its max.
