adjusting valves hot.
Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
gonna have to be butthole fast man. stone cold adjustment is easyier, you can take your time, and you wont get burned haha hot adjustment against cold is not any better. your not gonna run better because you did it hot, but W/e its your E30. do what you want.-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good lookingComment
the specs bently use comes striaght out of bmws abl's. so the hot spec would be for a tech that has to adjust them and doesnt have a few hours to let the engine cool off. there is no reason to do it hot if you can let it cool off. it will probly give you worse results325es/24v's/20psi/meth injection/
sigpicComment
it doesn't give you worse results. you are adjusting the exact spec that the engine will see while it is running. when it's cold you are basically hoping that the rate of thermal expansion is precise enough for your .010" clearance to grow to .012" hot. once I tried it and realized how much better it works, I would never go back to doing it cold. it also isn't that hard, it only takes about a half hour anyway which is fast enough to do it before it cools.Comment
good point. my results probably relied on the fact that it was my first time, I was outside and it was ~38F :neutral:it doesn't give you worse results. you are adjusting the exact spec that the engine will see while it is running. when it's cold you are basically hoping that the rate of thermal expansion is precise enough for your .010" clearance to grow to .012" hot. once I tried it and realized how much better it works, I would never go back to doing it cold. it also isn't that hard, it only takes about a half hour anyway which is fast enough to do it before it cools.Driving:1990 325iS, 2007 335i :devil:
past BMWs: 1987 325iS turbo, 1989 325i, 1995 525i, 2000 328CI, 2001 540i, 2008 135iComment
