Super noobie question
  • bernzpeed
    • 3917
    What's the difference between the 87 325i and 89 325i engine?
    89 E30 S52
    Transaction Feedback.
  • slammin.e28
    שמע ישראל
    • 12054
    Nothing. The 87 is just 2 years older.
      There actually is a difference between those two engines. The fuel injector rail and electrical connectors and engine harness are different and the 89 will have "weight improved" (read lighter) pistons.
        • 34839
        yeah, there are slight differences, but functionally they are identical.
        • slammin.e28
          שמע ישראל
          • 12054
          This is what I was getting at. ;)
          • SpecM
            • Oct 2005
            • 4531
            the cooling system is different between these two, but all the parts are interchangeable
            1989 cirrisblau-metallic 325i
            • bernzpeed
              • 3917
              the reason i'm asking is because i have an 89 325i that needs a new engine and i bought an 87 325i with only 63k miles on it. I have both cars in whole so I maybe able to use the wirings. So what exactly will I need?
              89 E30 S52
              • matias88e30
                • Dec 2009
                • 1110
                6 pack... chill, take your time... my its a 88 with a 89 engine.. basically all i used was the 89 ecu, didnt search if it was the same, just swap it.
                no more boosted m20, 91 318i...
                  Use the engine from the 87 and the wiring harness from the 89. Replace the water pump on the 87's engine with the later one and steal the cross over tube from the 89.
