M20 2.8L Stroker Build List, missing anything???
  • Overlord475
    • Dec 2010
    • 799
    Hey guys,
    Here is my 2.8L Stoker build list. Let me know if I'm missing something or if it can be found at a better price!
    Head Rebuild List
    Upper Gasket Set: $75 (VicR PP)
    Head Bolts: $30 (Metric Blue mcmaster.com
    PN: 91303A306)
    Intake Mani to CH Studs (8x45mm): $9 (PP)
    Camshaft: $190 (IE 272 Regrind)
    Rocker Arms: $260 (IE)
    Rocker Eccentrics & Nuts: $54 (BaV)
    Intake Valves: $144 (SS +1 IE)
    Exhaust Valves: $144 (SS +1 IE)
    Valve Steam Seal Kit: $10 (PP)
    Valve Springs: $144 (BvA)
    Valve Guides: $120 (VAC)
    Throttle Body Gasket: $5 (PP)
    Timing Belt Kit: $34 (PP)
    Water Pump: $50 (BvA)
    Thermostat: $25
    Aux/Interm Shaft Oil Seal: $8 (BvA)
    Machine Work: $200
    Misc hoses, sp, etc: $225
    Est. Total: ~ $1750.00
    Block Rebuild List
    Lower Gasket Set: $36 (VicR PP)
    Freeze Plugs: $18
    MaxSil Pistons: $500 (BvA)
    Connecting Rods: $40 (130mm ETA r3v)
    Main Rod Bolts: $84 (BvA)
    Crank Main Bolt: ????
    Crank Rod Bearings: $150 (VAC)
    Crank: $180 (M52 r3v)
    Crank Spacer/Adaptor: $60 (IE)
    Intermediate Shaft Bearings: $40
    ** 11 11 1 264 196
    ** 11 11 1 280 863
    Oil Pump: $160 (PP or IE)
    Headers: $200 (r3v GB)
    IE Oil Pan Gasket Windag: $48
    Exhaust Mani Stud/nut Kit: $20 (VAC)
    Machine Work: $200
    Est. Total: ~ $2000.00
    Est. Grand Total: ~ $3750.00
    Key:
    Red - Haven't found/priced yet
    Blue - Already bought
    Black - Need to buy
    PP – Pelican Parts
    IE – Ireland Engineering
    BaV – BavAuto
    VAC – VAC Motor Sports
    Thanks guys!
    --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
  • JiXer
    • 620
    Don't forget engine management :)
    Exhaust?
    Head and manifold porting?
    I have a cool trick for using an S52 throttle body.
    And don't forget to post dyno results.
    I am thinking about doing this exact build but with i pistons if I can't spring for the Wiseco's I want.
    J. Farina
    Yeah, thats me kicking up all that dirt!
    • briansjacobs
      • 1278
      I did not have good results with the IE 272 and rockers.
      Brian Jacobs
      • JiXer
        • 620
        I've never had a good experience with anything from those guys. Can you be more specific though. Its good info for others to have.
        J. Farina
        • matias88e30
          • Dec 2009
          • 1110
          Sounds good.. any ecu chip? e/m?, bigger injectors, fuel pump, fpr.
          no more boosted m20, 91 318i...
          • Overlord475
            • Dec 2010
            • 799
            Exhaust?
            I was thinking of the Miller WAR chip and MAF for management. It's plug and play, and can run up to 4 tunes on the one chip.
            Do you have a DIY link for the S52 TB set up? Interested to see that!
            The MaxSil pistons I am looking at are b25 replicas but with a 84.5mm bore and are much lighter / stronger. I stayed away from custom pistons because they are basically double the price. Though I would love to have used an S52 crank with 86mm custom pistons... 3.1L mmmmmmmm :twisted:
            I'd like to hear about this too! The reason I am going with the IE rockers is because of the GB going on right now for $240 which is the same as stock rockers @ $20 each. Figured if I was going to buy rockers anyway I might as well pick up these at the same price as I would for stock.
            Have you found a better cam option at a similar $190 price?
            • briansjacobs
              • 1278
              well you get what you pay for and the lower cost of going with IE cost me a shit ton of money. The problem was basically that pads on the rockers where not the same as the factory pads, I was not able to determine the difference in hardness compared to stock but the rockers would last on average 3 hours of run time before being totally worn out. I would then need to drain all oil (13Q in my car at $10 per Q) remover all rockers send back to IE repeat again till they refunded and I went with VAC billet + schrick cam.
              My advice is if you can not afford to do it right, dont do it at all! I have tried the cheap route and it was more expensive than doing it right.
              If you care to find my build thread there are pics of the destroyed rockers.
              Brian Jacobs
              • briansjacobs
                • 1278
                build thread
                Brian Jacobs
                • Overlord475
                  • Dec 2010
                  • 799
                  Was looking to use their Heavy Duty rockers not their Billets. Not sure if they have this pad issue also though?
                  http://store.nexternal.com/shared/St...unt2=303458809
                  Looks like they've stop selling the Billet version all together.
                  • briansjacobs
                    • 1278
                    glad I could do their R&D for them but really im not bitter
                    Brian Jacobs
                    • briansjacobs
                      • 1278
                      in hindsight you dont really need the billet rockers as you will never rev past 6500 with this motor. In all reality there is no reason to go past 6000 RPM with the build you are doing. You will have a real nice power band from 3K-6K
                      Brian Jacobs
                      • Larsinnj
                        • Jan 2009
                        • 134
                        Exhaust?
                        And what is that if I may ask? And will it work on throttle bodies from a euro s50b30?
                        • 619E30
                          • 1753
                          What do you plan on doing for fuel supply? Injectors? Fuel pump?
                          Originally posted by audiquattrot
                          bimmers b4 b*tches....remember that.
                          1990 Alpinweiss 325i - secret 500whp build
                          2000 Audi S4 B5 Laser Red
                          1990 Nissan 240sx - Drift Missile
                          2006 CBR600RR
                            • 34847
                            that honestly sounds like it could be a ZDDP problem? there are others who have had success with them. the castings, at least, are far superior to stock.
                            also, I'd much prefer OEM bolts to metric blues, which are technically just bolts that happen to fit into an M20. IMO the factory TTY bolts are superior in every way, the only thing better would be ARP or Raceware studs.
                            I would also not suggest spending money on a regrind, as the cam is one of the most important parts of building an M20 head. Better to save money on some of the other uneccesary upgrades and get a good cam. The stock eccentrics do not work with regrinds, so you will have to buy expensive oversized eccentrics, and I don't even know who sells them these days (turner? korman?).
                            • Overlord475
                              • Dec 2010
                              • 799
                              Originally posted by nando
                              .....I would also not suggest spending money on a regrind, as the cam is one of the most important parts of building an M20 head. Better to save money on some of the other uneccesary upgrades and get a good cam. The stock eccentrics do not work with regrinds, so you will have to buy expensive oversized eccentrics, and I don't even know who sells them these days (turner? korman?).
                              Can you give me an idea of what items I her listed are uneccesary upgrades? If stock works just as well of better then that works for me!
