Pulled the head and found a suprise!
  • nomansland92
    • 1657
    So i have the 88' ix and im doing the head gasket. Since the p/o never did the head bolt update one of the bolts was snapped. but after i got it all torn down and took the head off i was amazed on how clean it was. it has 200k + miles on it. You can still see the crosshatching clearly and there is no edges on the wall at all. Then once i looked at the head i noticed the intake valves were so clean the guides looked perfict not one spec of dirt even the seats were all good. It looks so clean it almost makes me think it was rebuilt not long ago. I mean 200k miles and still see the cross hatchings, and the guides looking that good ( by the was that spot in the wall is not a score it was just the camara)
    But If it was rebuilt Im sure they would have used new head bolts because why would they reuse the origanal hex bolts that were junked and stretched. So i don't think it was rebuilt but what a shock to find it this clean. So what are your ideas, Rebuilt or not?
    IX being restored here
    Ix turbo build here
  • deutschman
    • May 2008
    • 5958
    Cant see whats happening. Need large pictures!
      There may be more bore wear than is evident at the top of the cylinders. In fact I'll bet on it. The worst wear occurs at the bottom of the bore, but you can't see that without tearing down the bock and using a bore gage.
      • MonkeyMadness
        • 3251
        I think your sparkplug gapping is to tight..
        • george graves
          • 19996
          I'll edit this post with something meaningful after I buy a bigger monitor to see the picture.
          Originally posted by Matt-B
          • bernzpeed
            • 3917
            lmfao... i had to move away from the monitor by a quarter mile.
            89 E30 S52
            Transaction Feedback.
            • scottinAZ
              • Dec 2009
              • 1312
              doesnt really surprise me one bit. When I did my headgasket at 281K miles mine looked much the same inside. As Jlevie says, there may be more wear at the bottom of the cylinders, however if the motor is running good, I wouldnt be excessively concerned about it at this time. button it up and drive it like you stole it.
              I saved 15% on my Bimmer parts by switching to ...
              • nomansland92
                • 1657
                Ya sorry about the large pictures i just uploaded them to image shack straight from my phone and that's how they came out.
                Ya i really didn't think it was rebuilt, I guess even though the old owner never put new head bolts on he must of been using good gas and kept up with his oil changes. Ill be cleaning all day today and painting odds and ends tomorrow then its going back together.
                Thanks for the input everyone
                Ix turbo build here
                • nrubenstein
                  • 3148
                  My 333k M20 looks the same inside. Original head bolts on that one, too.
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                    • 37829
                    Same here, just took apart a Super Eta that had a broken odometer at 302k. Original head bolts and it looked perfect inside. We're going to put an i head on it and run that bitch as is.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • KenC
                      King of Kegstands
                      • 14396
                      Plug gap is too small. Adjust to .36-.4
                      Aren't those black streaks blow-by?
                      Even an engine with a million miles is likely to have the crosshatching still. It's an iron block... the rings don't really wear it away.
                      Originally posted by Gruelius
                      • scottinAZ
                        • Dec 2009
                        • 1312
                        Tell that to a chevy with chrome faced rings, they get a massive ridge and wear out the crosshatch in 100K or less.
                        • KenC
                          King of Kegstands
                          • 14396
                          The BMW ones are pretty low tension.
                          • SpecM
                            • Oct 2005
                            • 4531
                            plus, the iron block has a pretty high nickel content... that makes it harder
                            1989 cirrisblau-metallic 325i
                            • e30rapidic
                              • 2167
                              wow - never seen a spark plug that you gap in inches!
                              '87 325ic, powered by S50.
