Mark D chip install fail
  • actionpod
    • Dec 2010
    • 61
    So installed the Mark D chip out of an anti ESD bag, wearing a grounding strap, proper installation, etc. Key in on position, gross clicking sound- kind of like a quiet tazer or something to that effect. Back to on, clicking off. No start, but cranks. Reinstalled OEM chip and she runs beautifully again- so round two I did a really really slow install, just to see if I screwed something up. Identical symptoms, reinstalled OEM, runs great.
    I'm glad im still running fine- but I'd love my chip to work. Anyone had this problem? Do I have a fried chip?
    1988 325iX
    Protection? From who, "ze Germans?"
  • BrewCity11
    • Mar 2008
    • 2335
    Checklist.
    -what ECU is the Chip for?
    -What ECu did you put it in
    -did you install backwards?
    -where did you buy the chip from?
    turk@gutenparts.com
    • actionpod
      • Dec 2010
      • 61
      Originally posted by BrewCity11
      Checklist.
      -Product e30 173.6k9-9114 (91 octane, 14# injectors, DME 0 261 200 173)
      -Do I need to pull a number off the ecu or is 1988 325iX enough information?
      -This was one of the more "underlined" notes in the DIY I read, so I think I did it right. Not backwards if the notches are supposed to face the same direction. I checked before, checked after, and the notch in the direction it is is working with the OEM chip.
      -came with my car, from a reputable gentleman, to my knowledge never installed.
      Was I supposed to plug it in and wait 30 minutes for it to sync with everything? I waited 5 after hooking the battery back up the second time I attempted the install, but no dice.
      1988 325iX
        • 34844
        it's likely the '88 ix has a 153 ECU. AFAIK, there's no chip for those - and while I think it physically plugs in, you can't use a 1.3 chip in a 1.1 ecu.
        so yes, you need to read the # on the ecu. if it ends in 153, you need to find a 173 - they cost about $40.
        no you don't have to wait.
        • actionpod
          • Dec 2010
          • 61
          I will check on this. Thank you very much for the prompt help guys!
          1988 325iX
