Bad sputtering/misfire?
This is what I meant by taking back to stock form. Otherwise you cannot rule out the possibility that something with your maf conversion took a crap.
Also when you said CPS for some reason I was thinking of the CTS. However I don't think the CPS is the issue. If it was I don't think the car would run at all.
If your O2 sensor has an unknown history I would definitely change it. FWIW BMW recommends changing the O2 sensor every 50K.Comment
Good luck with this one Abby. Mine did the exact same thing, I mean exact.
Ended up being a fuel injector supposedly. Got that changed out, ran perfect for like 2 weeks and now its acting up again.
Fuck a M20, especially fuck a MAF kitted M20.harry/harout
Okay I see.This is what I meant by taking back to stock form. Otherwise you cannot rule out the possibility that something with your maf conversion took a crap.
And I'll be changing the O2 sensor this week hopefully. Thank you man.
Really? :(
What'd you end up doing Harry?Comment
Please buy a new CPS along with your 02 sensor. When I had troubles with mine, it would hold enough charge to turn the car on and to get me going on a cold running engine for 5-10 miles, after that the car would start to sputter and bog out as if it was starving for fuel. Finally it started to turn off on me, at one time I thought it was a bad ECU but after asking close to a dozen people and changing all of the related things close to the problem. I got it to the Castros to find out my CPS was cracked and had some wires exposed. I could have saved myself a lot of money if I just changed that first.@IRON-E30 aka Edwin:DComment
You're winning me over right now because when I turn on my car, I can get to where I want on a cold engine only for maybe 2 miles if that, then it will start dancing and sputter on me.Please buy a new CPS along with your 02 sensor. When I had troubles with mine, it would hold enough charge to turn the car on and to get me going on a cold running engine for 5-10 miles, after that the car would start to sputter and bog out as if it was starving for fuel. Finally it started to turn off on me, at one time I thought it was a bad ECU but after asking close to a dozen people and changing all of the related things close to the problem. I got it to the Castros to find out my CPS was cracked and had some wires exposed. I could have saved myself a lot of money if I just changed that first.
Think I'm making a trip to Ireland Eng. today then, thanks E.
Good luck with yours Harry. Did you also change the named items?Comment
Good for you, I hope you report back with good news.You're winning me over right now because when I turn on my car, I can get to where I want on a cold engine only for maybe 2 miles if that, then it will start dancing and sputter on me.
Good luck with yours Harry. Did you also change the named items?@IRON-E30 aka Edwin:DComment
Well, some good news and bad news I guess.
Changed to a brand new O2 sensor and didn't really get any improvements and still had a CEL light.
Disconnected the battery for 2 minutes, then turned on the car and my CEL went away. Took it out for a drive and I'd say it runs around 40% better now.
I still sputter, but my RPMs still go up, when giving some gas after letting go.
It used to sputter and hit a brick wall at around 3rpm and have no go at all.
I'm a little bit confident to drive it to the shop as I had zero before.
Bad news is my CPS bolt is stripped so I can't change that out at the moment :-|Last edited by ak-; 01-31-2011, 10:30 PM.Comment
