Engine oil in the intake
  • Bene
    • Feb 2011
    • 358
    Today when replacing the cone filter, I noticed engine oil in the maf. Could this be a contributing factor or related symptom of my engine steadily idling between 1500 & 2000?
  • mr.vang
    • 4371
    for some reason a small amount of oil always finds its way to the intake. i'm pretty sure its normal unless it look like someone dump a good amount on it.
    • Dagamus(NM)
      • 618
      Vacuum leak will cause both high idle and oil in the intake elbow/afm.
      Bitch tube seals love doing this, so does splits along the bottom of the hose from the tb to the top of the valve cover.
      Check that hose first.
      Gun control means using both hands
      Sex, Drugs, Rock 'n roll. Pick two.
        In addition to those causes increased blowby in an engine with over 150k on it and worn valve seals will increase the amount of oil being dumped into the intake. As will leaking dipstick o-rings, a leaking oil fill cap seal, or leaking valve cover gaskets.
        • Adrian_Visser
          • Jun 2006
          • 2823
          Some oil in the intake elbow is normal, your high idle is most likely from something else. oil on the AFM isn't really normal though are you sure that it isn't filter oil?
          '89 Alpine S52 with goodies
          • Bene
            • Feb 2011
            • 358
            it's dark, so I'm sure it's engine oil.
            I think the problem is that the PO put a cone filter on the MAF and it's not mounted to anything. it's just resting on the frame. I want to put an airbox back in.
            • immajackuup
              • Dec 2010
              • 1132
              x2,just like all honda motors.
                • 37829
                That makes no sense. I'm not defending the cone setup since it's really just something that sounds good but it has nothing to do with having oil in your intake.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • Dagamus(NM)
                  • 618
                  So the afm is not secured to anything? I'm still thinking vacuum leak. Remove the boot and inspect for cracks. Check to see if the screw that sets the throttle plate has been adjust it back down to a normal idle if it has. If your car has tired rings, the high idle when cold may be pressurizing your crank case sending more oil up the breather than normal.
                  I am still thinking vac leak though, cheaper and easier to fix than rings or valve seals. Rule that out first.
                  • Bene
                    • Feb 2011
                    • 358
                    it idles high when warm. but yeah, it has over 240,000 on it (estimated), so that makes sense.
                    And yes, the maf and cone filter are just flopping around like an 80's porn star's tits. to the point where there's a big crack in the elbow which now may or may not be sealed by duct tape.
                    • Dagamus(NM)
                      • 618
                      That crack is most likely the problem. A new elbow is pretty cheap from rmeuropean or autohausaz.
                      Once replaced, check the screw at the top of the throttle body and see if it brings the idle down. PO most likely opened that to maintain idle and not stall out from the vac leak.
                      • hotballs
                        • 1155
                        So are you running a MAF on an m20? Or are you talking about the AFM....
