Block warped??
  • Mlarsen
    • 4082
    Block warped??
    I know its highly unlikely with an m20. I just put a h/g in may car and I got oil coming from the h/g. Its fucking irritating, I don't want to pull the head off again. Any suggestions?
  • StereoInstaller1
    GAS
    • 22679
    Quit putting oil in it?
    Just kidding, I got nothing.
    Closing SOON!
    Thanks for 10 years of fun!
    • Mlarsen
      • 4082
      I don't know it seems like I didn't torque the head bolts right. I feel like I did right. Am I supposed to retorque after I run it? I feel like such a idiot right now...
      • lolcantturn
        • 4588
        Yes you are.
        Initially torque them to 30ft/lbs
        Wait 15mins, then torque it to 44ft/lbs
        Then after running the engine for 25mins, tighten the bolts 25*.
        Make sure you tightened them in the right sequence as well.
        Originally posted by TSI
        OEM+
        • Mlarsen
          • 4082
          I'm an idiot, disregard thread. haha I KNEW I forgot something!!
          • lolcantturn
            • 4588
            Hopefully that fixes everything up. Keep us updated!
            OEM+
            • moatilliatta
              • 6148
              also run a flat edge on the cylinder head and block if you disassemble.
              @Zakspeed_US
                The head bolts, being torque to yield, are not to be re-torqued after installation of the head. Since they are torque to yield bolts, each time the head is installed new bolts must be used.
                Was the head surfaced when it was off? Did you use new head bolts?
                • Mlarsen
                  • 4082
                  Well followed last step and still get oil from h/g... fml. I used new head bolts, head to went to machine shop, and cleaned the block pretty damn good. I'm thinking maybe I did fuck up on the torque specs. Could i just oull the head bolts and replace with the proper torque specs?
                  • CorvallisBMW
                    Long Schlong Longhammer
                    • 13039
                    Originally posted by lolcantturn
                    Yes you are.
                    I'm pretty sure that's the method for m30 engines.
                    IIRC, as per my Bentley manual, the proper way is to torque them all to something like 38 ft-lbs, then all another 90*, then all another 90* again.
                    • Mlarsen
                      • 4082
                      thats how I did it.
                      • accident
                        • 7303
                        then you did it right.
                        Moral of this story?
                        • redhatpat
                          • Aug 2005
                          • 656
                          then something is warped.
                          • lolcantturn
                            • 4588
                            That's straight off the Bentley manual for me.
                            OEM+
                              What is the history on this engine? Was a severe overheat in it's past?
                              If you think that you may have not properly installed the head bolts they can be replaced, one at a time, in the order shown in the Bentley manual.
