How do you tell if an m20 is l-jet or motronic?
  • Brezzi
    • Jan 2010
    • 1630
    Just started rewirng the junk yard m20 that's going in my car and I think it might be l-jet b.c the fuel rail looks different than the one on my 88. How exactly can I tell? Also how can i convert it to motronic?
    Thanks,
    -Brent
    • 34839
    only early euro cars have L-jet, like the early 323i.
    what kind of M20 is it? if it's an eta or a B25, it's not L-jet.
    • Brezzi
      • Jan 2010
      • 1630
      It's a b25 so why does the rail look different?
        • 34839
        how different does it look? I think early fuel rails have the inlet and return on opposite ends, while the later rails have the inlet and return on the same end (by the FPR).
        there was never a B25 that ran on L-jet though.
        • Brezzi
          • Jan 2010
          • 1630
          Good to know I'm gunna take some pictures of it tonight so i can highlight what I'm talking about.
          • M-technik-3
            • 18946
            If it's something like run away.
            • Brezzi
              • Jan 2010
              • 1630
              Haha na it's not even close to that different the wires coming off the injectors just look like they are bundled differently or something I just haven't seen it before so I wasnt sure what was up.
                There are two fuel injector configurations that were used on M20B25 engines. The early configuration (from 9/86 through 8/87) has the fuel supply connection at the rear of the rail and the injector connectors are separate and a part of the engine harness. The late configuration has the fuel supply connection next to the FPR, the injector connectors are within a plastic chase, and the cable from the chase connects to the engine harness via C191.
                • stoker1010
                  • 10
                  Motronic has dizzie on the camshaft. L-Jet has dizzie on the side of the block.
