Does fuel injector cleaner work?
  • M20power93
    • Feb 2011
    • 84
    Does fuel injector cleaner actually work? If so what brands are reccomended for the M20B25 motors? Theres nothing big done to my car i just wanna make sure they're clean.
  • MTechnikII
    • Jun 2007
    • 83
    just a marketting gimmik, if you are using good fuel, and the engine is running well and do regular maintenance and oil change, no need for an additive or cleaner,
    Henry
    • e30iwite
      • Jan 2010
      • 83
      I use it every oil change. I think it works. No way to tell for sure. But I think it's a small price to pay for peace of mind.
      • Bglad
        • Jul 2010
        • 562
        Sea Foam.
        • lateracer
          • Sep 2009
          • 302
          Don't get me wrong, I'm a fan of sea foam. But for less than $150, you can buy a set of used M50 injectors, have them professionally cleaned and rebuilt and swap them out for your stocks (M50 injectors have an improved design that atomizes fuel better). Much better results than any injector cleaner could ever hope to deliver.
          • bernzpeed
            • 3917
            what does it mean "atomizes fuel better"?
            89 E30 S52
            Transaction Feedback.
            • MaxBell
              • 1391
              Definition: In terms of automotive liquid fuels, atomization occurs by forcing fuel through a small jet (opening) under high pressure to break it into a fine misted spray.
              Pronunciation:
              āt'ə-mīz zā'shən
              Examples:
              Diesel fuel is atomized in an engine's combustion chamber when it is forced through the fuel injector nozzle.
              REMEMBER: Be safe and have fun is Rule Number 1.
              The Epic Unbuild of Clint Eastwood
              • bmw325csi
                • May 2007
                • 4045
                Originally posted by Bglad
                Sea Foam.
                Through intake and fuel
                harry/harout
                • Jaxx_
                  • Dec 2009
                  • 1880
                  it is my understanding that injectors are usually matched to intake valve design, just FYI.
                  I like running seafoam, but I think that most injector cleaning isn't going to help too much, if at all. Remember that the injectors have a filter in them too, you can't clean those by forcing particles through it, they have to be back washed. I prefer to put seafoam through the intake than in the gas tank.
