M20 head job
  • DrtyE30
    • 656
    M20 head job
    I just blew my head gasket and i was looking at having a spare head done up nice. It's and m20b25 and i want to have it port and polished and maybe a 3 angle valve job done. To get to the point, if i do get a valve job does anyone know if it is possible to do a 4 or 5 angle on those and what to do for a valve train, do they make over sized valves for those? As well as anything else I would need, maybe a website or two.
    thanks
    91 318is M50 swap
    89 325ic
    12 WRX Daily
    86 325e Sold
    88 325is (Parted out)
    06 330XI (Sold)
    91 318is-M20 turbo Sold :(
    91 318ic (Sold)
    87 528e (Sold)
    93 318is E36 (Parted out)
    92 325ic (Parted out)
    94 325i E36 (Sold)
    88 325ix (Sold)
    Click my Signature to see the build!!^
    • 37832
    If you're running a stock 2.5 just a regular port and polish is all you need and should bother with. Oversized valves, upgraded rockers, and valve springs are just going to cost you money you don't need to spend.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • DrtyE30
      • 656
      That's a good tip thanks! I have a thought in the back of my head of maybe boosting it, only like 8lb's would you think I would still be okay with low boost like that?
      91 318is M50 swap
      89 325ic
      12 WRX Daily
      86 325e Sold
      06 330XI (Sold)
      91 318ic (Sold)
      87 528e (Sold)
      94 325i E36 (Sold)
      88 325ix (Sold)
      • Kershaw
        • 11822
        let's be honest. you're not going to turbocharge it.
        AWD > RWD
          If you want to do a head up right for maximum performance you want to do what Jim at Metric Mechanic does. There is a write up on the MM site about what they do to wring the last little bit out of an M20 head.
          • hooken m
            • 1537
            lets be honest. your an asshole
            Originally posted by evandael
            a car is a car. call it a dildo, i'd still drive the hell out of it.
            • will61
              • 533
              Maybe, but I understand what he is saying. For instance, I talk a lot about boosting my hooptie but I doubt I'll do it within a couple years.
              just my
              just doin track stuff :-P
              "When was the last time you drove an e30 without a smile on your face?"
              • Ceeker
                • Sep 2009
                • 2821
                save your money and freshen up the valve seats, change the guides if these is play and put fresh valve seals in. and deck the head. for less then a couple hundred you have a fresh head as long as the rockers and cam are not worn excessively. throw it in and your car will come alive in comparison to what it feels like after 200k. All the noise about doing what you want is a waste of money at this point and won't serve you one bit unless you do what was mentioned above. you're into a grand to do a head up properly. you'll only see marginal difference unless you do other things to to the car to compliment this modification.
                • SkiFree
                  • Jun 2011
                  • 2766
                  date people, check the date.
                  ADAMS Autosport
                  • clarkson
                    • 231
                    Question is, has he boosted it yet ;)
                    Pulling my hair out with all these friggin BMW's:
                    2000 M5 Winter beater
                    1984 318i Coupe 2.5 S14 going in the car below.
                    1988 M3 Lachssilber: I'm the second owner, currently recommissioning.
                    • Vivek
                      attention whore/retard/bitch
                      • 6167
                      1992 Mauritiusblau Vert
                      2011 Alpinweiss 335is coupe
                      2002 540i/6 Black/Black
                      2003 GSX-R 750 (RIP)
                      • efficient
                        • Feb 2012
                        • 3312
                        Lol
